You first need to note that for performance purpose, we do not recommend to do this.
You can make a copy of your Audirvana database and store it in your NAS, after doing this you need to change the the location of your database on Windows 10 and MacOS so it will use the database stored in your NAS.
To go to your Audirvana database using Finder:
Open its Go menu
Pressing the option (or alt) key, and maintain it pressed. This reveals the Library command in this Go menu.
Click on this Library command
In the Finder window that opens, navigate into Application Support, then Audirvana
You’ll find there the file AudirvanaPlusDatabaseV2.sqlite (This is the one for Audirvana 3.5, the other is for the older version 3).
