Unable to change integer mode with Sony XM5 as output
Audirvana Origin 2.2.5 (20205)
Windows 11 (22621) with 16GB physical RAM
Connected account of : XXX XXX
	Globally: ON
	Per track: OFF
AUTO: C:\Users\XXX\OneDrive\Desktop\FILES\VODS
Library database path: C:\Users\XXX\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
XXX
Max. memory for audio buffers: 408MB
Local Audio Engine: WASAPI
Headphones (WH-1000XM5)
Model UID:BTHENUM{0000110b-0000-1000-8000-00805f9b34fb}_VID&0002054c_PID&0df0
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{24602f86-6bef-46cc-bcab-d45b4d050d31}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Selected device:Headphones (WH-1000XM5)
Manufacturer: Microsoft
Model name: Bluetooth Peripheral Device
Model UID: BTHENUM{0000110b-0000-1000-8000-00805f9b34fb}_VID&0002054c_PID&0df0
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{24602f86-6bef-46cc-bcab-d45b4d050d31}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Local devices found : 3
Device #0: Headphones (WH-1000XM5)
Device #1: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0285&SUBSYS_10431C62&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c8d18198-d0f7-43c0-b35c-ac452c062209}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Device #2: AI Noise-cancelling Output (ASUS Utility)
Manufacturer: ASUSTek Computer Inc.
Model UID: *IGOVAC
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ead4a25d-76a0-441e-9a4e-486d5bd62d7a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
First thing move your buffer size to approximately 4000mb
Gotcha. Thanks!
