Unable to connect to my NAS
:slight_smile: ello,
I can’t get my remote app to connect to my NAS. I’m using Fedora 41 server as distro on this NAS.
The service is running
riitchy@tiamat ~> sudo systemctl status audirvanaStudio.service
● audirvanaStudio.service - Run audirvanaStudio
     Loaded: loaded (/etc/systemd/system/audirvanaStudio.service; enabled; preset: disabled)
    Drop-In: /usr/lib/systemd/system/service.d
             └─10-timeout-abort.conf, 50-keep-warm.conf
     Active: active (running) since Sun 2024-12-01 11:35:30 CET; 21min ago
 Invocation: 579474a947f9417db93ada79bf288061
   Main PID: 769375 (audirvanaStudio)
      Tasks: 68 (limit: 18903)
     Memory: 8.2M (peak: 8.7M)
        CPU: 45ms
     CGroup: /system.slice/audirvanaStudio.service
             └─769375 /opt/audirvana/studio/audirvanaStudio
Dec 01 11:35:30 tiamat systemd[1]: Started audirvanaStudio.service - Run audirvanaStudio.
Dec 01 11:35:30 tiamat audirvanaStudio[769375]: /opt/audirvana/studio/audirvanaStudio: /lib64/libcurl.so.4: no version information available (require>
Dec 01 11:35:30 tiamat audirvanaStudio[769375]: 2024-12-01 11:35:30.780 [info]:         =============  Started Logging, Audirvana Studio 2.9.4 Linux >
Dec 01 11:35:30 tiamat audirvanaStudio[769375]: 2024-12-01 11:35:30.783 [info]: Running on Linux 6.11.8-300.fc41.x86_64 x86_64
Dec 01 11:35:30 tiamat audirvanaStudio[769375]: 2024-12-01 11:35:30.783 [info]: No language set in settings, using system language: en_US.UTF-8
Dec 01 11:35:30 tiamat audirvanaStudio[769375]: 2024-12-01 11:35:30.793 [warning]: EULA not accepted yet, showing it
Dec 01 11:35:30 tiamat audirvanaStudio[769375]: 2024-12-01 11:35:30.796 [info]: RemoteServer: Server started and advertised on port 44197
One the remote app on my iPhone, I see the name fo my NAS appearing, but when I tap on it nothing happens. Actually I see a little load icon on the right of my NAS’ name, but it doesn’t connect.
I opened the 44197 port in firewall-cmd, so I don’t understand.
Maybe anybody can help ? TIA :slight_smile:
What do you mean by this cryptic message? Can you post a screenshot of where you see it?
With Linux, you need to mount the NAS through SMB (CIFS in Linux language). See: How to create a Samba share :: Fedora Docs
When you do, you create a mounting point, which acts like a local folder on Fedora. You need to add that local folder to Audirvana in the settings > local tab of the Remote App.
Here
Maybe I didn’t understand correctly what Audirvana for linux does, I thought I would be able to play my music stored on the NAS, by running Audirvana linux on it, and accessing it through Audirvana remote…
Ok, it is a NAS running Fedora, that I misunderstood .
Yes, that should work.
Hi @jmtennapel, I also have trouble with Audirvana Remote on iOS getting ‘stuck’ on the selection screen. I see you have Audirvana running on your macbook and your NAS, so try the following: select ‘macbook’ and (hopefully) connect; then in the Remote app select the Settings icon and swap the connection to ‘tiamat’. That works for me.
Nope, it doesn’t work… Maybe selinux is blocking
If available, try running Audirvana Remote on an Android device. For me, this problem only occurs with Remote on iOS. ¯_(ツ)_/¯
I’m experiencing the same, quite often I’m not able to connect my IOS remote app to Audirvana service running on linux (I’m using 2 instances, one is VM in Truenas, one is bare-metal Void linux)… I guess it’ll have something to do with how Avahi daemon works in certain environments…
