From what I see, this is not a new topic, but my issue seems to be a new angle on this one. Im getting “Unable to open and audio file for playback” seemingly at random from hi Rez files procured from the various sites. It doesn’t seem to be relative to any one type of file (Flac, Apple Losless etc.) or sample rate. It does seem to be centered around older downloads but can’t say for sure. Tidal works fine, however, I do have to sign on every so often when it drops from the Audirvana UI.
Older Mackbook Pro, running High Sierra 10.13.6. Just installed the latest Audirvana Update. Here is the Debug:
macOS 10.13.6 with 8192MB RAM
Registered to Martin Sorensen
Globally: ON
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX to DSD128 with filter type B 8th order
Replay Gain: by album
AUTO: /Users/martinsorensen/Music
iTunes/Music library synchronization: last synchronized on Mon Nov 23 08:29:30 2020
Library database path: /Users/martinsorensen/Library/Application Support/Audirvana/HDtracks/AudirvanaPlusDatabaseV2.sqlite
FOSTEX USB AUDIO HP-A4
Model UID:FOSTEX USB AUDIO HP-A4:1019:0013
UID:AppleUSBAudioEngine:FOSTEX:FOSTEX USB AUDIO HP-A4:00001:1
Sample rate switching latency: 0.5s
ID 0x2e Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:28 UID:AppleHDAEngineOutput:1B,0,1,1:0
Stream ID 0x2f 2 channels starting at 1
4 virtual formats:
12 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:28 UID: AppleHDAEngineOutput:1B,0,1,1:0
