If I login, I am able to play audio file when streaming from Qobuz. But playing a second album or track gives “unable to play an audiofile”.
I have to login again to be able to play another album. I’m streaming from a MacbookPro > Marantz ND8006 (USB DAC) > Marantz PM15.
What can I do?
This is the debug info:
Audirvana Studio 1.8.1 (10801)
macOS 10.15 with 8GB physical RAM
Connected account: (Karel Matla)
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/music/
iTunes/Music library synchronization: last synchronized on Mon Jul 19 23:02:37 2021
Library database path: /Users/karelmatla/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 54723
Max. memory for audio buffers: 6042MB
D&M HOLDINGS INC. ND8006
Model UID:ND8006:154E:300A
UID:AppleUSBAudioEngine:D&M Holdings Inc.:ND8006:14100000:1
Active Sample Rate: 96kHz
Limit bitdepth to 24bit: ON
ID 0x30 Built-in Output
Model Name: Apple Inc. Built-in Output
Model UID: AppleHDA:40
Stream ID 0x31 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:40 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
UPnP devices found : 15
Device #0: ID 0x0 Marantz SR6015 UID: uuid:020dc7cc-c692-1114-0080-0006784e0536 Location: http://192.168.68.119:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Marantz ND8006 UID: uuid:f4e3f756-8402-119e-0080-0005cd8e7057 Location: http://192.168.68.121:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 Denon Home UID: uuid:13be4753-0f35-1bbc-0080-00a96f02adf2 Location: http://192.168.68.114:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Marantz SR6015 UID: uuid:da409684-d3eb-111b-0080-0006784e0536 Location: http://192.168.68.119:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Marantz SR6015 UID: uuid:d337a11f-8de8-1a85-0080-0006784e0536 Location: http://192.168.68.119:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Marantz SR6015 UID: uuid:59930986-9962-26c8-108b-651d18c11525 Location: http://192.168.68.119:60006/upnp/desc/aios_device/aios_device.xml
Device #6: ID 0x0 Marantz SR6015 UID: uuid:b7a17837-e568-3bfa-bf8f-4fdd01f62c69 Location: http://192.168.68.119:60006/upnp/desc/aios_device/aios_device.xml
Device #7: ID 0x0 Marantz ND8006 UID: uuid:5756ed29-e76d-1ee4-0080-0005cd8e7057 Location: http://192.168.68.121:60006/upnp/desc/aios_device/aios_device.xml
Device #8: ID 0x0 Marantz ND8006 UID: uuid:017bd586-ed91-1869-0080-0005cd8e7057 Location: http://192.168.68.121:60006/upnp/desc/aios_device/aios_device.xml
Device #9: ID 0x0 Marantz ND8006 UID: uuid:c3f0d1eb-8bb4-f8e3-a777-97dfba24e254 Location: http://192.168.68.121:60006/upnp/desc/aios_device/aios_device.xml
Device #10: ID 0x0 Marantz ND8006 UID: uuid:4e9806f3-30c5-c42d-155c-4f45f3746b8c Location: http://192.168.68.121:60006/upnp/desc/aios_device/aios_device.xml
Device #11: ID 0x0 Denon Home UID: uuid:2a7130ea-5baa-15f1-0080-00a96f02adf2 Location: http://192.168.68.114:60006/upnp/desc/aios_device/aios_device.xml
Device #12: ID 0x0 Denon Home UID: uuid:ef6e0353-09f0-1229-0080-00a96f02adf2 Location: http://192.168.68.114:60006/upnp/desc/aios_device/aios_device.xml
Device #13: ID 0x0 Denon Home UID: uuid:ead6e997-32a1-7a90-1e65-d8dbced62147 Location: http://192.168.68.114:60006/upnp/desc/aios_device/aios_device.xml
Device #14: ID 0x0 Denon Home UID: uuid:f798ece4-fe1f-1f75-cdbf-51541621b594 Location: http://192.168.68.114:60006/upnp/desc/aios_device/aios_device.xml
