All ok prior to 2.9.3 update. Now all Qobuz music gone. Cannot re-connect via preferences. All re-boots failed. TIDAL service still OK. Assistance please & thank you.
Hi @GVM,
Can you please elaborate on the reconnect you tried using your preference? Do you get any error while you try to connect?
Hi & yes as follows: Other login already in progress.
I made a change to your Audirvāna account, can you please try again to log to Qobuz?
G’day Antoine, sorted & works now. Many thanks.
