Audirvana Studio 2.9.2 (20902)
Windows 11 (22631) with 8GB physical RAM
Connected account of : Audi100
Available network interfaces:
Ethernet 2 ({3fad4d28-609a-4839-8ac7-xxxxxxxxxxxx}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Kaspersky Plus
VST3 plugin #0: C:\Program Files\Common Files\VST3\MathaudioRoomEQ.vst3
ClassID: F2AEE70D00DE4F4E4D617468536E7231
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
AUTO: D:\von Audio-CD
Library database path: C:\Users\username\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 4734
Listening on 2001:9e8:65f7:5800:b6ef:f183:671b:xxxxx on port 50855
TIDAL: Connected as PREMIUM
Font size: regular
Language: Systemsprache
Meine Musik
Radios
Podcasts
Streaming
Lokal
Startup view: Meine Musik: Alben
Number of paired remotes: 2
Screen saver disabled: no
Kopfhörer (SMSL USB AUDIO)
Model UID:USB\VID_152A&PID_85DD&REV_0353&xxxxx
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e40d0f7d-91cd-4e0e-83cf-f14b024xxxxx}#{e6327cad-dcec-4949-ae8a-991e976xxxxx}
Active Sample Rate: 96kHz
Selected device:Kopfhörer (SMSL USB AUDIO)
Manufacturer: Microsoft
Model name: SMSL USB AUDIO
Model UID: USB\VID_152A&PID_85DD&REV_0353&xxxxx
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e40d0f7d-91cd-4e0e-83cf-f14b024249c2}#{e6327cad-dcec-4949-ae8a-991e976xxxxx}
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
Kernel Streaming capable
MQA Decoder device
DSD via PCM 1.1
Simple stereo device: No
Device #0: Kopfhörer (SMSL USB AUDIO)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e40d0f7d-91cd-4e0e-83cf-f14b024249c2}#{xxxxxcad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speaker (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0245&SUBSYS_103C8BF6&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d74af33b-43b6-4746-9157-86f9e236daa4}#{xxxxxcad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
UPnP devices found : 1
Device #0: Denon AVR-S970H
UID: uuid:f46becac-c3bf-14b0-0080-000678exxxxx
Location: http://192.168.178.35:xxxxx/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon AVR-S970H
