UnhandledException: The data is invalid
Program all of a sudden will not start and I get the message UnhandledException: The data is invalid when loading the program on Windows 11.
Hi @TheAbyss2022,
Can you send us the audirvana_studio.dmp file you should have on your desktop at [email protected]?
to show AppData folder:
