Universal Gapless mode and VST/AU
I have a question regarding the use of Universal Gapless Playback mode for UPnP.
When this is enabled and VST/AU plug-ins are also selected in the “Processing” section, will those VST/AU plug-in’s processing be applied?
I understand that real-time will have to be disabled. I just want to check if VST/AU will work over Universal Gapless Playback mode.
Hi @soundgals,
The effect should be applied whether or not Universal Gapless playback is disabled. You need to disable the Real-time mode.
OK, that’s good to know. Thanks. I’ll give it a listen.
