UPnP Stack Error version 3.5.19
Just installed Audirvana and did the upgrade, and now find version 3.5.19 generates a stack error.
See message:
And my Network is marked with a RED Explanation mark.
Any help would be appreciated.
Thanks Rob
See message:
Thanks Rob
Anyone had an answer to this - I have the same issue.
I have tried disabling all other uPNP services.
I should also mention that I use a Netgear Nighthawk X6S Tri-Band WiFi Mesh Extender
Hello @gjhodgson and @roberth5, you are not using the latest version of Audirvana. Can you update your Audirvana to the latest version 3.5.28 (Audirvana Settings>Generel>Check for Updates) and tell us if you still have the issue? Make sure you donât have other application that would use UPnP at the same time of Audirvana when youâll run your test.
I had the same issue with 3.5.28. Just to confirm, this error relates to other uPNP services already running - so therefore I sould see if anything else is running?
Bonjour,
Jâai Ă©galement le mĂȘme sujet depuis quelques versions. Je ne peux plus sĂ©lectionner la sortie UPNP (Devialet Phantom) mais jâai un gros point dâexclamation rouge. A noter, quand je lance directement le player QOBUZ, je peux sans problĂšme choisir la sortie UPNP et diriger le son sur mes enceintes. Je vous joins Ă toutes fins uties le debug info. Merci dâavance pour votre aide !
Audirvana Mac Version 3.5.28 (3558)
macOS 10.15.2 with 24576MB RAM
Licence enregistrée pour Philippe MEVEL
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Dec 11 01:22:55 2019
Library database path: /Users/philippemevel 1/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 21504MB
TA-ZH1ES
Model UID:TA-ZH1ES:054C:0BDA
UID:AppleUSBAudioEngine:Sony Corporation:TA-ZH1ES:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
ID 0x39 TA-ZH1ES Manufacturer:Sony Corporation
Model UID:TA-ZH1ES:054C:0BDA UID:AppleUSBAudioEngine:Sony Corporation:TA-ZH1ES:14100000:1
11 available sample rates up to 1411200Hz
1411200
Stream ID 0x3a 2 channels starting at 1
42 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 1411.2kHz
62 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 1411.2kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x2f Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x39 TA-ZH1ES Manufacturer: Sony Corporation Model UID: TA-ZH1ES:054C:0BDA UID: AppleUSBAudioEngine:Sony Corporation:TA-ZH1ES:14100000:1
UPnP not started
@gjhodgson and @pmevel , if you are using another service that is using the UPnP protocol then youâll have this problem. If you look at your debug info youâll see this: âUPnP not startedâ which means that there is another app using UPnP (in this case its the Qobuz app)
Merci Damien pour la suggestion ! Mais jâai ce statut en permanence, mĂȘme quand lâapplication Qobuz nâest pas lancĂ©e. Pour en avoir le coeur net, je lâai dĂ©sinstallĂ©e, Ă©teint lâordinateur puis rallumĂ©. Jâai toujours le mĂȘme point dâexclamation ! Mais jâai quand mĂȘme trouvĂ© la solution : jâai supprimĂ© le fichier plist et jâai relancĂ© lâapplication. Et lĂ miracle, ça remarche ! MĂ©thode Ă peut-ĂȘtre diffuser en anglais aux autre utilisateurs⊠Cordialement, Philippe
What is the plist file and where can I find it (Mac)?
I have also undertake further studies - I can dual boot my MacBook so tried Audirvana on Windows 10. uPNP worked fine. So this tells me that itâs a problem with the Mac version of Audirvana on Catalina (latest release) as all of the network topology etc⊠is otherwise identical.
Also, based on Audirvana running on Windows 10 I get very choppy playback (my only source is Tidal). Again this must be another software specific issue because I have no other problems with other playback software (e.g. Linn Kazoo). My network is >500MBps average (Netgear Orbi), so shouldnât be an issue there.
I would like to get Audirvana working is I like the interface, but so far I have been unable to evaluate the sound quality. Happy to try again if there is a resolution.
Hello, here is how you can find the preferance (plist) file : you go on the icon of Audirvana in you app folder, make a right click and select the second option (in french "afficher le contenu du paquet). The finder opens a folder named âContentsâ, open it and you will find a file named info.plist. Move it on the desktop, try to launch Audirvana. Then put back the info plist where it was, and launch Audirvana again. For me, it worked, and I could see all the devices that where reachable through UPNP Protocol. I hope this will do the trick for you ! Philippe
Thanks - didnât work for me. I tried reinstalling the package as well.
I also have no âuPNP not startedâ error in the log file.
Application error log is too large for me to paste in.
Guess I was lucky ! Sorry for you that it didât workâŠ
Hello @pmevel, be careful with what youâve done. You maybe find a workaround but this could damage Audirvana since you are touching to the core of the app.
Hello Damien ! I didnât do anything critical, the plist file was just removed from the folder and putted back at the same place. I didnât delete or modify it. And the good point whith Mac is that if you screw something, there is Time Machine ⊠Anyway, it seems that this workaround worked only for me !
Philippe
Naim DAC V1 - has worked fine with other software (Audiolinux, Moode, Euphony, Windows etcâŠ)
Hello, i just bought Audirvana Licence and i have the same problem.
I Have 2 macbooks ( The two with catalina), one works perfectly but the other one i have the massage " 203 UPNP-E-Socket Bind "
Of course, i tried to close all the UPNP app on the others divices.
Can you help me ?
My debug info
Audirvana Mac Version 3.5.34 (3564)
macOS 10.15.4 with 8192MB RAM
Licence enregistrée pour Amara
Library database path: /Users/will/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Built-in Output
Model UID:
UID:
ID 0x40 Sortie intégrée Manufacturer:Apple Inc.
Model UID:AppleHDA:54 UID:AppleHDAEngineOutput:1F,3,0,1,1:0
3 available sample rates up to 96000Hz
Stream ID 0x41 2 channels starting at 1
3 virtual formats:
3 physical formats
Local devices found : 3
Device #0: ID 0x2e Apowersoft_AudioDevice Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_apowersoft_driver_ApowersoftDevice:Soundflower UID: ApowersoftEngine:0
Device #1: ID 0x40 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:54 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #2: ID 0x29 Pro Tools Aggregate I/O Manufacturer: Apple Inc. Model UID: com.Avid.ProToolsAnalogIOAggregateDevice UID: com.Avid.ProToolsAnalogIOAggregateDevice
UPnP not started
Hello @Will, this means the device you want to use is used by another app or you need to select the right output in Audirvana audio output by clicking on the Network section:
