UPnP not Enable
Since i install the new upgrade 1.8.7 on Studio he stop to recognize the UPnP services!Does it happen with anyone here Mac M1 and Mac Intel i5
Did any settings get changed PCM-RAW perhaps? Mine is working fine still Monterey 12.1
Post your debug if you can’t get it going
Restart all your gear and computer perhaps ?
Thanks i already did it
I already did it still the same
Change RAW-PCM switch
If not post your debug
I Will dot it when i get Home
Thanks to enveryone the problem was in the UPnP Receiver sotm ultra 200 neo
