USB noise isolation in Studio?
Anyone tried a Matrix X-SPDIF between their computer and DAC? And if so, how much of a difference did you notice when using Audirvana direct thru USB or the Matrix then DAC? Thanks for any input out there.
It is a DDC (Digital to Digital Converter)… What DAC are you using? Do you only have S/PDIF input to your DAC or digital playback device?
Using a PS Audio DSD DAC MK1. Can’t get the right settings to make the Matrix pass audio. I want to use the I2S output to the DAC. Any suggestions? Thanks for responding
I doubt this DDC will be an improvement on the DirectStream DAC technology… Make sure you have the latest firmware for your DAC… The I²S port on the DAC is primarily for connecting an SACD player.
Maybe ask what these folks did? Matrix X-SPDIF 2 - Accessories and Tweaks - PS Audio
