Good Afternoon. I’m thinking about that is there any way to use my Audirvana remote through a shared mobile network? My idea is basically when I’m on the go and use my mobile network and laptop to power my DAC can’t I connect them somehow? I used Roon for some months and with it I just had to skip the message of “Connect to Wi-Fi” and it discovered my network automatically. Please help me to find a possible solution for this, plus because sometimes my home network is instable and I can’t use the remote through that time too
If you create a hotspot on your phone and connect your laptop to it, it might work. Try it.
Yeah I tried it thanks but unfortunately it did not worked
Mine works fine with a mobile hotspot. Hotspot to the Mac and iPhone on LTE. Remote on the phone fine, Studio on the Mac fine.
I do it all the time.
