V2 - coupure Airplay
Bonjour,
V2, le problème persiste. la lecture est régulièrement coupée (1/4 de seconde) et cela m’empêchèrent d’écouter de la musique avec audirvana (tous les autres programmes vont bien heureusement).
Audirvana Studio 2.0.0 (20000)
macOS Version 12.6 (assemblage 21G115) with 32GB physical RAM
Connected account of : jm moretti
	No plugin active
SW volume control: ON
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Thu Apr 21 12:19:46 2022
Library database path: /Users/sherpa2/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 58196
Max. memory for audio buffers: 3050MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
APPLE, INC. AIRPLAY
Model UID:6db82248-248d-40e2-8d5b-0a0a1e79e00c-68803110398-Audio
Selected device:AirPlay
Manufacturer: Apple, Inc.
Model name: Apple, Inc. AirPlay
Model UID: 18a35bdb-c39d-46ab-8103-357f32b79bed-147332091597053-Audio
ID 0x57
1 available sample rates up to 44100Hz
0 Airplay connected device(s):
Stream ID 0x58 2 channels starting at 1
1 virtual formats:
1 physical formats
Device #0: ID 0x57 AirPlay
Device #1: ID 0x4b Haut-parleurs MacBook Pro
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs MacBook Pro
Try to play using built in audio device.
You have 32gb of memory, put the buffer at 20000 not 3000. Hog mode if off turn it on… and see
