Various problems With Cambridge CXN V2 Dac
Hello I have just moved Audirvana version 1.114.0 to a 2020 iMac and there is quite a few teething problems some similar to previous problems I had before I have a Cambridge CxnV2 Dac connected via Ethernet it all worked okay with the the previous 2015 iMac but now it will now only play certain file formats from my Synology nas once again it cues the songs up as if it’s going to play it but then nothing happens if I change it to play through the iMac speakers everything works fine also for some reason there seems to be constant song analiizing going on with it going back to certain folders time and time again The folders it’s scanning are not that large and I do not have rescan enabled so I have no idea why it keeps going this finally the Cxnv2 will not wake from standby anymore it actually needs to be on before or Audirvana recognises it, please can somebody advise me on these matters
Budgie
What do you mean by “moving”? I think you should do a fresh install of the program on the new computer. If you already did this, I’m sorry, I can’t be of a big help.
Good luck!
Check the “send as RAW PCM” setting.
yes sorry i re installed !
hi just changed it is it supposed to help play all the different formats? it seems better but still doesn’t play everything
If you play it as PCM, the device doesn’t care what format it is.
What doesn’t play?
OK thanks I Have a lot of file formats and it now seems to play everything but DSD
Can you paste the debug info here?
Audirvana Studio 1.14.0 (11400)
macOS 12.5.1 with 40GB physical RAM
Connected account of : barry warren
Max allowed volume: 49.268
Sync list: 16 folders
AUTO: /Volumes/music/A
AUTO: /Volumes/music/B
AUTO: /Volumes/music/Bruce Springsteen
AUTO: /Volumes/music/C
AUTO: /Volumes/music/D
AUTO: /Volumes/music/E
AUTO: /Volumes/music/F
AUTO: /Volumes/music/G
AUTO: /Volumes/music/H
AUTO: /Volumes/music/I
AUTO: /Volumes/music/J
AUTO: /Volumes/music/K
AUTO: /Volumes/music/L
AUTO: /Volumes/music/M
AUTO: /Volumes/music/N & O
AUTO: /Volumes/music/P
Library database path: /Users/barrywarren/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56845
Preferred device: CAMBRIDGE AUDIO CXNV2 (15) Model UID:Cambridge Audio CXNv2 UID:uuid:a86355c1-4b2b-41a7-928f-c20ba9b441ab
Currently playing to UPnP device at 24 bits 5644.8kHz
UPnP device at http://192.168.1.67:8050/a86355c1-4b2b-41a7-928f-c20ba9b441ab/description.xml
ID 0x0 CXNv2 (15)
Manufacturer: Cambridge Audio
Model Name: CXNv2
Model UID: Cambridge Audio CXNv2
UID: uuid:a86355c1-4b2b-41a7-928f-c20ba9b441ab
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: Yes
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/mpeg:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
14 virtual formats:
0 physical formats
NrTracks: 2
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXNv2 (15) Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3763 uuid:a86355c1-4b2b-41a7-928f-c20ba9b441ab 00206a15 image/png 48 48 8 /a86355c1-4b2b-41a7-928f-c20ba9b441ab/CA-roundal-48x48.png image/jpeg 48 48 24 /a86355c1-4b2b-41a7-928f-c20ba9b441ab/CA-roundal-48x48.jpg image/png 120 120 8 /a86355c1-4b2b-41a7-928f-c20ba9b441ab/CA-roundal-120x120.png image/jpeg 120 120 24 /a86355c1-4b2b-41a7-928f-c20ba9b441ab/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RenderingControl/RenderingControl1.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RenderingControl/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /a86355c1-4b2b-41a7-928f-c20ba9b441ab/ConnectionManager/ConnectionManager1.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/ConnectionManager/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /a86355c1-4b2b-41a7-928f-c20ba9b441ab/ContentDirectory/ContentDirectory1.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/ContentDirectory/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /a86355c1-4b2b-41a7-928f-c20ba9b441ab/AVTransport/AVTransport1.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/AVTransport/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RecivaRadio/RecivaRadio.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RecivaRadio/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /a86355c1-4b2b-41a7-928f-c20ba9b441ab/UuPlaylist/Playlist.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/UuPlaylist/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RecivaSimpleRemote/RecivaSimpleRemote.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RecivaSimpleRemote/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /a86355c1-4b2b-41a7-928f-c20ba9b441ab/StreamMagic6/StreamMagic6.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/StreamMagic6/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /a86355c1-4b2b-41a7-928f-c20ba9b441ab/SMSearch/SMSearch.xml /a86355c1-4b2b-41a7-928f-c20ba9b441ab/SMSearch/invoke /a86355c1-4b2b-41a7-928f-c20ba9b441ab/SMSearch/event DMR-1.50 M-DMP-1.50
UPnP devices found : 1
Device #0: ID 0x0 CXNv2 (15) UID: uuid:a86355c1-4b2b-41a7-928f-c20ba9b441ab Location: http://192.168.1.67:8050/a86355c1-4b2b-41a7-928f-c20ba9b441ab/description.xml
Max. memory for audio buffers: 37888MB
Local devices found : 4
Device #0: ID 0x3b Hue Sync Audio Manufacturer: Philips Lighting B.V. Model UID: AudioDriverPluginDevice_ModelUID UID: AudioDriverPluginDevice_UID Model Name: Philips Lighting B.V. Hue Sync Audio
Device #1: ID 0x80 iMac Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. iMac Speakers
Device #2: ID 0x58 Microsoft Teams Audio Manufacturer: Microsoft Corp. Model UID: MSLoopbackDriverDevice_ModelUID UID: MSLoopbackDriverDevice_UID Model Name: Microsoft Corp. Microsoft Teams Audio
Device #3: ID 0x31 AirBeamTV Audio Manufacturer: AirBeamTV B.V. Model UID: AirBeamTVDevice_ModelUID UID: tv.airbeam.audiodriver_v2_2 Model Name: AirBeamTV B.V. AirBeamTV Audio
As DSD capability select DoP 1.0 or 1.1.
thanks where is this in the settings please ?
In the DAC output settings, if I remember well. You need to stop playback to change that.
sorry is this in Audirvāna or the Cambridge dac settings i can’t find it anywhere
In Audirvana.
Thanks for your help I managed to sort it by choosing no dsd for the maximum dsd rate
