In the last few days changing volume in the interface either doesn’t work or does not reflect changes, either using +/- or dragging the slider.
lowered:
lowered:
Hello @TheCat,
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Here we go.
I did wonder if it could be due to a streamer software update?
SW volume control is Off - maybe a red herring, it was on an older debug dataset when the slider adjustment updated the numerical volume. Think I’ll restart the streamer.
Audirvana Mac Version 1.6.1.3 (10601)
macOS 10.13.6 with 16384MB RAM
No plugin active
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 5 folders
Manual: (OFFLINE) /Volumes/AudioHD/
Manual: (OFFLINE) /Volumes/Public/Audio Purchases
Manual: (OFFLINE) /Volumes/Public/Shared Music
Manual: (OFFLINE) /Volumes/4TB WD
AUTO: /Volumes/My Passport for Mac/Audirvana
Library database path: /Users/x/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 63034
Preferred device: NAIM streamer
Model UID:Naim streamer
UID:uuid:x
Currently playing to UPnP device at 32 bits 96kHz
UPnP device at http://192.168.1.156:33206/xxx.xml
ID 0x0 Naim
Manufacturer: Naim Audio
Model Name:
Model UID: Naim
UID: uuid:
8 available sample rates up to 5644800Hz
5644800
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get:*:text/xml:DLNA.ORG_PN=DIDL_S
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/3gpp:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/l16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/l16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/l16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
rtsp-rtp-udp:*:text/xml:DLNA.ORG_PN=DIDL_S
rtsp-rtp-udp:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
rtsp-rtp-udp:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
rtsp-rtp-udp:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
rtsp-rtp-udp:*:audio/3gpp:DLNA.ORG_PN=HEAACv2_L2_320
rtsp-rtp-udp:*:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
rtsp-rtp-udp:*:audio/l16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/l16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/l16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get::audio/flac:
http-get::audio/x-ms-wma:
http-get::audio/x-flac:
http-get::audio/x_pm_flac:
http-get::application/ogg:
http-get::audio/l16;rate=44100;channels=1:
http-get::text/xml:
http-get::audio/l16;rate=44100;channels=2:
http-get::audio/ogg:
http-get::audio/mpeg:
http-get::audio/l16;rate=48000;channels=1:
http-get::audio/vorbis:
http-get::audio/l16;rate=48000;channels=2:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/x-wav:
http-get::audio/mp4:
http-get::audio/wave:
http-get::audio/aac:
http-get::audio/3gpp:
http-get::audio/x-dsf:
http-get::audio/x-dff:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-ms-wma:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/x_pm_flac:
rtsp-rtp-udp::audio/vnd.dlna.adts:
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:
rtsp-rtp-udp::text/xml:
rtsp-rtp-udp::audio/l16;rate=44100;channels=2:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/mpeg:
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/l16;rate=48000;channels=2:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/mp4:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/3gpp:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-dff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
20 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 0:05:24
CurrentURI: http://192.168.1.227:49152/audirvana/audio_63.wav
CurrentURIMetadata:
dc:titleAre 'Friends' Electric?</dc:title>
dc:creatorTubeway Army</dc:creator>
upnp:artistTubeway Army</upnp:artist>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/45/07/0607618000745_600.jpg</upnp:albumArtURI>
upnp:albumReplicas</upnp:album>
nextURI: http://192.168.1.227:49152/audirvana/audio_64.wav
nextURIMetadata:
dc:titleThe Machman</dc:title>
upnp:originalTrackNumber3</upnp:originalTrackNumber>
PlayMedium: NETWORK
<?xml version="1.0"?>1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetMediaInfo_Ext
InstanceID
in
CurrentType
out
CurrentMediaCategory
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
RecordMedium
out
RecordStorageMedium
WriteStatus
out
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetCurrentTransportActions
InstanceID
in
Actions
out
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
X_DLNA_GetBytePositionInfo
InstanceID
in
TrackSize
out
X_DLNA_CurrentTrackSize
RelByte
out
X_DLNA_RelativeBytePosition
AbsByte
out
X_DLNA_AbsoluteBytePosition
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
TransportState
string
STOPPED
PAUSED_PLAYBACK
PAUSED_RECORDING
PLAYING
RECORDING
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
NO_MEDIA
TRACK_AWARE
TRACK_UNAWARE
string
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
SD
PC-CARD
MMC
CF
BD
MS
HD_DVD
RecordStorageMedium
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
SD
PC-CARD
MMC
CF
BD
MS
HD_DVD
string
NONE
string
CurrentPlayMode
string
NORMAL
REPEAT_TRACK
REPEAT_ONE
REPEAT_ALL
NORMAL
TransportPlaySpeed
string
1
1
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
string
0:EP
1:LP
2:SP
0:BASIC
1:MEDIUM
2:HIGH
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
512
CurrentTrack
ui4
0
512
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
LastChange
string
A_ARG_TYPE_SeekMode
string
ABS_TIME
REL_TIME
TRACK_NR
ABS_COUNT
REL_COUNT
X_DLNA_REL_BYTE
string
ui4
string
string
string
0
qq:X_QPlay_SoftwareCapabilityQPlay:2</qq:X_QPlay_SoftwareCapability>
Naim
Naim Audio
Naim all-in-one audio player
Naim
xxx
https://www.naimaudio.com/product/uniti-nova
xxx
uuid:x
image/png
120
120
24
/LibRygelRenderer-120x120x24.png
image/png
48
48
24
/LibRygelRenderer-48x48x24.png
image/png
32
32
24
/LibRygelRenderer-32x32x24.png
image/png
128
128
24
/LibRygelRenderer-128x128x24.png
image/png
240
240
24
/LibRygelRenderer-240x240x24.png
image/png
480
480
24
/LibRygelRenderer-480x480x24.png
image/png
600
600
24
/LibRygelRenderer-600x600x24.png
image/jpeg
120
120
24
/LibRygelRenderer-120x120x24.jpg
image/jpeg
48
48
24
/LibRygelRenderer-48x48x24.jpg
image/jpeg
32
32
24
/LibRygelRenderer-32x32x24.jpg
image/jpeg
128
128
24
/LibRygelRenderer-128x128x24.jpg
image/jpeg
240
240
24
/LibRygelRenderer-240x240x24.jpg
image/jpeg
480
480
24
/LibRygelRenderer-480x480x24.jpg
image/jpeg
600
600
24
/LibRygelRenderer-600x600x24.jpg
/xml/ConnectionManager.xml
/Control/LibRygelRenderer/RygelSinkConnectionManager
/Event/LibRygelRenderer/RygelSinkConnectionManager
/xml/AVTransport2.xml
/Control/LibRygelRenderer/RygelAVTransport
/Event/LibRygelRenderer/RygelAVTransport
/xml/RenderingControl2.xml
/Control/LibRygelRenderer/RygelRenderingControl
/Event/LibRygelRenderer/RygelRenderingControl
dlna:X_DLNADOCDMR-1.51</dlna:X_DLNADOC>
UPnP devices found : 1
Device #0: ID 0x0 Naim UID: uuid:x
Max. memory for audio buffers: 548MB
Device #0: ID 0x34 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x3f HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{AC10-4120-3034394C} Model Name: Apple Inc. HDMI
The Naim setting is volume controle : No
Yes, that was my thought but I found an older log which had the same entry despite being able to adjust volume with numerical volume changing correctly in Audirvana.
Odd.
