is there a thread for bugs and issues?
my volume shows -8.4dB, it doesn’t move if I step up or step down the volume
Hi @cosmicpoems,
I moved your message to a new category. You can create a thread to report your issue but make sure it has not been reported in the past by searching for it
In your case i would like to know more about your setup. Can you send us a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>My account
hello, the +/- buttons are working, it’s just stuck at -8.4dB no matter if I step up or step down the volume
Audirvana Origin 2.0.0 (20000)
macOS Version 12.6 (Build 21G115) with 16GB physical RAM
Connected account of : AI
Sync list: 5 folders
AUTO: /Volumes/Samsung T7/96 kHz
AUTO: /Volumes/Samsung T7/192 kHz
AUTO: /Volumes/Samsung T7/CD
AUTO: /Volumes/Samsung T7/HI-RES
AUTO: /Volumes/Samsung T7/SA-CD
Library database path: /Users/ai/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49962
Active method: UPnP
Preferred device: [UPnP] Yamaha Corporation RX-V685 Model UID:Yamaha Corporation RX-V685 UID:uuid:9ab0c000-f668-11de-9976-0c8e29d162ca
Selected device:RX-V685
Manufacturer: Yamaha Corporation
Model name: RX-V685
Model UID: Yamaha Corporation RX-V685
UID: uuid:9ab0c000-f668-11de-9976-0c8e29d162ca
UPnP device at http://192.168.1.16:49154/MediaRenderer/desc.xml
ID 0x0
Volume control: Yes
DSD capability: Raw DSD (MSB)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get::audio/l16;channels=2;rate=44100:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=44100:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=48000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=48000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=32000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=32000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=88200:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=88200:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=96000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=96000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=64000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=64000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=22050:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=22050:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=24000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=24000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=16000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=16000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=11025:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=11025:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=12000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=12000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=8000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=8000:dlna.org_pn=lpcm
http-get::audio/l16:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmdrm_wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmdrm_wmafull
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_192
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_320
http-get::audio/mp4:dlna.org_pn=aac_iso
http-get::audio/mp4:dlna.org_pn=aac_iso_192
http-get::audio/mp4:dlna.org_pn=aac_iso_320
http-get::audio/3gpp:dlna.org_pn=aac_iso
http-get::audio/3gpp:dlna.org_pn=aac_iso_192
http-get::audio/3gpp:dlna.org_pn=aac_iso_320
http-get::audio/x-ms-wma:*
http-get::audio/x-flac:
http-get::audio/x-mpeg:
http-get::audio/x-aac:
http-get::audio/x-mp3:
http-get::audio/x-mp4:
http-get::audio/x-mpg:
http-get::audio/x-wav:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/mp3:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/wav:
DLNA 1.5: Yes
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 3:22:53
CurrentURI: http://192.168.1.18:49152/audirvana/gaplessAudio_10.wav
CurrentURIMetadata: dc:titleAudirvana gapless playback</dc:title> upnp:classobject.item.audioItem.musicTrack</upnp:class> http://192.168.1.18:49152/audirvana/gaplessAudio_10.wav
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Stop,Pause,Seek,X_DLNA_SeekTime,Next,Previous
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 RX-V685 Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-V685 V685 http://www.yamaha.com/ 0B7073A3 uuid:9ab0c000-f668-11de-9976-0c8e29d162ca image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.16/ http://192.168.1.16:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl /YamahaRemoteControl/desc.xml urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 1412Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 RX-V685 Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-V685 V685 http://www.yamaha.com/ 0B7073A3 uuid:9ab0c000-f668-11de-9976-0c8e29d162ca image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.16/ http://192.168.1.16:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl /YamahaRemoteControl/desc.xml urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 1412UPnP devices found : 2
Device #0: ID 0x0 : Décodeur TV UHD
UID: uuid:00ababad-7947-1048-8a00-482952c2c1c2
Manufacturer: SoftAtHome
Model name: SoftAtHome Media Renderer
Device #1: ID 0x0 : RX-V685
Location: http://192.168.1.16:49154/MediaRenderer/desc.xml
Model name: RX-V685
Local Audio Engine: CoreAudio
Device #0: ID 0x4a MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Can you try to switch to your MacBook Pro speakers and cehck if you have the same behavior and then switch back you your Yamaha and try again?
yes by switching to macbook speakers and switching back to yamaha works
also, the “volume value” is so different from origin 1.0.7, it used to be a percentage i think
thanks
