Audio output set to “JF Light Industries Volumio UPNP/AV” doesn’t work.
Audirvana Studio 1.11.0 (11100)
Windows 11 (22000) with 16GB physical RAM
Connected account of : xxx
Effects plugins NOT ACTIVEUPSAMPLING:
Phase linearAUDIO VOLUME:
SW volume control: ONLIBRARY SETTINGS:
Sync list: 5 folders
AUTO: \NAS2497F6\Music\DSD
AUTO: \NAS2497F6\Music\FLAC
AUTO: \NAS2497F6\Music\Lossless\96khz
AUTO: \NAS2497F6\Music\Lossless\192khz
Library database path: C:\Users\arcto\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqliteRemote Control server:
Listening on 192.168.50.195 on port 53805ACTIVE STREAMING SERVICES
TIDAL: Connected as HIFI=================== AUDIO DEVICE ========================
Preferred device: JF Light Industries Volumio-UPnP/AV Model UID:JF Light Industries Volumio-UPnP/AV UID:uuid:548a2cb5-2925-37ea-1818-dca632459359
UPnP device at http://192.168.50.158:49152/uuid-548a2cb5-2925-37ea-1818-dca632459359/description.xml
Volumio-UPnP/AV
Manufacturer: JF Light Industries
Model Name:
Model UID: JF Light Industries Volumio-UPnP/AV
UID: uuid:548a2cb5-2925-37ea-1818-dca6324593596 available sample rates up to 192000Hz
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: Yes
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
Use as stereo device only: No1 output streams:
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz finite lengthCurrent device transportInfo:
CurrentTransportStatus: ERROR_OCCURRED
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInZjM5NzZjZDA2OGMyNmRiMDgxODdkNjYzMjQ3NWU5ZjBfNjAubXA0/0.flac?token=1646203939~OTkzODkyNWVmYmE5ZmE3ZmQ3NDVlYzU0N2M3Y2JiZWY2ZTRmZWYxNQ==
CurrentURIMetadata: <?xml version="1.0" encoding="utf-8"?>dc:title</dc:title>mpdupnp:classobject.item.audioItem.musicTrack</upnp:class>
nextURI:
nextURIMetadata:
PlayMedium: HDD
WriteStatus: NOT_IMPLEMENTEDCurrent device AVT service description:
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Volumio-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.5.8 libupnpp 0.20.2 image/png 64 64 32 /uuid-548a2cb5-2925-37ea-1818-dca632459359/icon.png /uuid-548a2cb5-2925-37ea-1818-dca632459359/presentation.html uuid:548a2cb5-2925-37ea-1818-dca632459359 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-548a2cb5-2925-37ea-1818-dca632459359/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-548a2cb5-2925-37ea-1818-dca632459359/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-548a2cb5-2925-37ea-1818-dca632459359/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-548a2cb5-2925-37ea-1818-dca632459359/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-548a2cb5-2925-37ea-1818-dca632459359/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-548a2cb5-2925-37ea-1818-dca632459359/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-548a2cb5-2925-37ea-1818-dca632459359/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-548a2cb5-2925-37ea-1818-dca632459359/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-548a2cb5-2925-37ea-1818-dca632459359/evt-urn-schemas-upnp-org-service-ConnectionManager-1UPnP devices found : 11
Device #0Retro Room UID: uuid:cf515ef8-edea-1cea-0080-0005cdd48962 Location: http://192.168.50.142:60006/upnp/desc/aios_device/aios_device.xml
Device #1Office UID: uuid:a0cac570-e7f8-16e5-0080-0005cdbc9bee Location: http://192.168.50.40:60006/upnp/desc/aios_device/aios_device.xml
Device #2Volumio-UPnP/AV UID: uuid:548a2cb5-2925-37ea-1818-dca632459359 Location: http://192.168.50.158:49152/uuid-548a2cb5-2925-37ea-1818-dca632459359/description.xml
Device #3Office UID: uuid:9b590f76-04b6-1297-0080-0005cdbc9bee Location: http://192.168.50.40:60006/upnp/desc/aios_device/aios_device.xml
Device #4Office UID: uuid:20dc838c-8db0-188d-0080-0005cdbc9bee Location: http://192.168.50.40:60006/upnp/desc/aios_device/aios_device.xml
Device #5Office UID: uuid:fe709fa3-26a7-870c-eeec-32b7f8bc6bcd Location: http://192.168.50.40:60006/upnp/desc/aios_device/aios_device.xml
Device #6Office UID: uuid:302c5de9-7a5e-8623-c94b-5442e229570a Location: http://192.168.50.40:60006/upnp/desc/aios_device/aios_device.xml
Device #7Retro Room UID: uuid:723afe2e-a852-12fd-0080-0005cdd48962 Location: http://192.168.50.142:60006/upnp/desc/aios_device/aios_device.xml
Device #8Retro Room UID: uuid:098bf2c2-6f7a-17af-0080-0005cdd48962 Location: http://192.168.50.142:60006/upnp/desc/aios_device/aios_device.xml
Device #9Retro Room UID: uuid:7e2abc2b-81df-eb69-a773-b98e49dd5115 Location: http://192.168.50.142:60006/upnp/desc/aios_device/aios_device.xml
Device #10Retro Room UID: uuid:a373743d-b3fb-4283-a9b7-837d4b28d377 Location: http://192.168.50.142:60006/upnp/desc/aios_device/aios_device.xmlMax. memory for audio buffers: 3704MB
Device #0: Speakers (iFi (by AMR) HD USB Audio) Manufacturer: Microsoft Model UID: USB\VID_20B1&PID_3008&REV_0730&MI_00 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f311eaf7-c10b-43b0-8842-df2ca021dbd4}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: iFi (by AMR) HD USB Audio
Device #1: Speakers (Realtek(R) Audio) Manufacturer: Realtek Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0236&SUBSYS_10280A78&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{76778ab2-f1ff-4ca0-8557-fbab3039a497}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Realtek(R) Audio
