VOLUMIO Rivo streamer certification
As I am interested in purchasing this valuable Italian streamer VOLUMIO Rivo, I wanted to ask if anyone knows whether it is by chance being certified as a patner by AUDIRVANA.
Hi @UltimaLegione,
I have no problem with the unit certification. However, I will need to talk about it with Volumio. Do you know the best way to contact them on this? You can do the certification yourself and send me the result by email at [email protected]
Audirvana and Volumio work together, even though Volumio has its own player software, but there is one thing you should be aware off: Volumio also works as a UPnP renderer, but Audirvana often can not locate the Volumio streamer once you want to connect again and the lock of Audirvana is not on the streamer anymore.
You have to wake the Volumio, go to the setting, slide the UPnP renderer setting off and on again and then Audirvana will see the Rivo. Very annoying, and not the fault of Audirvana.
I confirm the circumstance of Audirvana occasional failure to detect the VOLUMIO Rivo streamer.
But from the tests I’ve done, I’ve also found that the failure to recognise and the occasional need for VOLUMIO Rivo to restart only occurs when the streamer is connected to the following DAC via USB.
When either the S/PDIF Coax RCA output or the AES/EBU balanced XLR output of the VOLUMIO Rivo are used instead, everything always works flawlessly.
Not my experience. SPDIF was used
In which operating environment is your Audirvana Studio installed: Windows, iOS, or Linux?
Hello Mr Antoine,
i have succeeded in obtaining approval from VOLUMIO’s Technical Service for the AUDIRVANA certification procedure of their VOLUMIO Rivo streamer and I will proceed as soon as possible and with their support to the procedure set out in the check list you sent me, integrating it with the video I will perform during the verification procedure.
With regard to the contact required in Volumio, you can refer to Mr Davide of VOLUMIO TECH SUPPORT (with whom I have just sent a message today) by writing directly to the e-mail address [email protected]
Best regards.
Pino.
Hi @UltimaLegione,
Perfect, thank you for this; I will email him right away.
