No issues with WASAPI and Qobuz. “Error starting device playback” when I switch to Asio (no upsampling or with files). Pops and songs not finishing when it runs… once in a while.
DSD 64 can work, just switching to PCM… It locks in Error starting…
Audirvana 3.5.45
Bandwidth at 0dB = 92.2038
Phase = 0
Sync list: 2 folders
AUTO: E:
AUTO: E:\backup-003836
Library database path: C:\Users\jeanf\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1820MB
Local Audio Engine:ASIO 2 driver version 2
T+A PDP3000 USB ASIO
Model UID:T+A PDP3000 USB ASIO
T+A PDP3000 USB ASIO Manufacturer:
Model UID:T+A PDP3000 USB ASIO UID:T+A PDP3000 USB ASIO
13 available sample rates up to 45158400Hz
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: T+A PDP3000 USB ASIO Manufacturer: Model UID: T+A PDP3000 USB ASIO UID: T+A PDP3000 USB ASIO
Device #1: TEAC ASIO USB DRIVER Manufacturer: Model UID: TEAC ASIO USB DRIVER UID: TEAC ASIO USB DRIVER
