UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192 - 354 - 384
DSD supported sample rate : 64 - 128
DSD Over PCM setting : None
MQA capability : No
Volume:
Volume can be changed : Yes
Device can mute - unmute: Yes
There is currently an issue affecting the value displayed in Audirvāna for this device, Weiss is aware of this and is working on it.
Playback:
Best upsampling setting for device : None
Setting do not send RAW PCM activated : No
Playback Control:
Gapless playbak option enabled : No
