Have you checked Marantz receivers via HDMI?
Also Onkyo and some Yamaha receivers will do multi channel DSD over HDMI.
Yes, we own a Yahama receiver that plays multi channel DSD over HDMI from our Oppo and Sony blu-ray players. However, I would expect streaming DSD from Audirvana might sound better and it would offer a much better user interface than the primitive UPNP/DLNA browsing interface in any of these devices, which require a screen to be on.
Did you try to play from Audirvana through HDMI? I see that Audirvana shows the HDMI as interface when the Mac is connected to a TV or Monitor with audio output.
Yes, I’ve tried sending DSD over HDMI from Mac mini to Yamaha RX-A3060 receiver, but unfortunately that didn’t work. I can only get Audirvana to work when I set it to convert DSD to PCM.
When I play from Audirvana to the receiver over the network (UPnP), it plays native DSD64 (or anything upsampled to DSD64) with very high fidelity – clearly better than stereo over HDMI. When I play a 5.1 channel DSD64 file though, Audirvana sends it out as DSD64 stereo. So I get DSD streaming to work fine, but not for multichannel.
Below is the relevant section from Audirvana’s debug info. It contains the line “DSD capability: Raw DSD (MSB)” and:
Can play native DSD: Yes
This makes me wonder… if the Yamaha can play native multichannel DSD from our blu-ray player, then why not multichannel over the network? Clearly Audirvana is obeying the “2 channel” limitation… but what would happen if Audirvana ignored this and sent out the multichannel DSD instead??? Perhaps I should contact Damien and ask whether he has tried… Multichannel DSD to the Yamaha receiver would be a breakthrough for multichannel sound quality without us having to spend a significant amount of money on a multichannel DAC (which would require us replacing the receiver as well because it doesn’t have analog multichannel inputs)…
Cheers,
– Mark
Preferred device: Mastering Room Model UID:Yamaha Corporation Mastering Room UID:uuid:9ab0c000-f668-11de-9976-00a0ded9d439
- UPnP device at http://10.0.8.49:49154/MediaRenderer/desc.xml*
- ID 0x0 Mastering Room Manufacturer:Yamaha Corporation*
- Model UID:Yamaha Corporation Mastering Room UID:uuid:9ab0c000-f668-11de-9976-00a0ded9d439*
- 44100*
- 48000*
- 88200*
- 96000*
- 176400*
- 192000*
Volume control: No
MQA capability - Auto-detect MQA devices: No*
- Not a MQA device, user set to not MQA*
Device audio channels - Preferred stereo channels L:0 R:1*
- Channel bitmap: Ox3, layout:*
Channel 0 mapped to 0*
Channel 1 mapped to 1*
- http-get::audio/L16;channels=2;rate=44100:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=44100:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=48000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=48000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=32000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=32000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=88200:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=88200:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=96000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=96000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=64000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=64000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=22050:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=22050:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=24000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=24000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=16000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=16000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=11025:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=11025:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=12000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=12000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=2;rate=8000:DLNA.ORG_PN=LPCM
- http-get::audio/L16;channels=1;rate=8000:DLNA.ORG_PN=LPCM
- http-get::audio/L16:DLNA.ORG_PN=LPCM
- http-get::audio/mpeg:DLNA.ORG_PN=MP3
- http-get::audio/x-ms-wma:DLNA.ORG_PN=WMABASE
- http-get::audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
- http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMABASE
- http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMAFULL
- http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
- http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192
- http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
- http-get::audio/mp4:DLNA.ORG_PN=AAC_ISO
- http-get::audio/mp4:DLNA.ORG_PN=AAC_ISO_192
- http-get::audio/mp4:DLNA.ORG_PN=AAC_ISO_320
- http-get::audio/3gpp:DLNA.ORG_PN=AAC_ISO
- http-get::audio/3gpp:DLNA.ORG_PN=AAC_ISO_192
- http-get::audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
- http-get:*:audio/x-ms-wma:**
- http-get:*:audio/vnd.dlna.adts:**
- http-get:*:audio/x-flac:**
- http-get:*:audio/x-mpeg:**
- http-get:*:audio/x-aac:**
- http-get:*:audio/x-mp3:**
- http-get:*:audio/x-mp4:**
- http-get:*:audio/x-mpg:**
- http-get:*:audio/x-wav:**
- http-get:*:audio/3gpp:**
- http-get:*:audio/aacp:**
- http-get:*:audio/aiff:**
- http-get:*:audio/x-aiff:**
- http-get:*:audio/flac:**
- http-get:*:audio/mpeg:**
- http-get:*:audio/aac:**
- http-get:*:audio/m4a:**
- http-get:*:audio/mp3:**
- http-get:*:audio/mp4:**
- http-get:*:audio/dsd:**
- http-get:*:audio/x-dsd:**
- http-get:*:audio/x-dsf:**
- http-get:*:audio/x-dff:**
- http-get:*:audio/wav:**
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
- Channel #0 :Stream 0 channel 0*
- Channel #1 :Stream 0 channel 1*
13 virtual formats:
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 176.4kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 192kHz*
- 2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 2822.4kHz*
0 physical formats
*Current device transportInfo: *
- CurrentTransportState: NO_MEDIA_PRESENT*
- CurrentTransportStatus: OK*
- CurrentSpeed: 1*
*Current device MediaInfo: * - NrTracks: 0*
- MediaDuration: 0:05:07*
- CurrentURI: *
- CurrentURIMetadata: *
- nextURI: *
- nextURIMetadata: *
- PlayMedium: NONE*
- RecordMedium: NOT_IMPLEMENTED*
- WriteStatus: NOT_IMPLEMENTED*
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
GetCurrentTransportActions
InstanceID
in
Actions
out
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
NONE
RecordStorageMedium
string
NOT_IMPLEMENTED
string
string
CurrentPlayMode
string
NORMAL
NORMAL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
LastChange
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
string
ui4
1
0
<dlna:X_DLNADOC xmlns:dlna=“urn:schemas-dlna-org:device-1-0”>DMR-1.50</dlna:X_DLNADOC>
Mastering Room
Yamaha Corporation
http://www.yamaha.com/
AV Receiver
RX-A3060
A3060
069377C3
image/jpeg
48
48
24
/Icons/48x48.jpg
image/jpeg
120
120
24
/Icons/120x120.jpg
image/png
48
48
24
/Icons/48x48.png
image/png
120
120
24
/Icons/120x120.png
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/event
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/event
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/event
http://10.0.8.49/
yamaha:X_device
yamaha:X_URLBasehttp://10.0.8.49:80/</yamaha:X_URLBase>
yamaha:X_serviceList
yamaha:X_service
yamaha:X_specTypeurn:schemas-yamaha-com:service:X_YamahaRemoteControl:1</yamaha:X_specType>
yamaha:X_controlURL/YamahaRemoteControl/ctrl</yamaha:X_controlURL>
yamaha:X_unitDescURL/YamahaRemoteControl/desc.xml</yamaha:X_unitDescURL>
</yamaha:X_service>
yamaha:X_service
yamaha:X_specTypeurn:schemas-yamaha-com:service:X_YamahaExtendedControl:1</yamaha:X_specType>
yamaha:X_yxcControlURL/YamahaExtendedControl/v1/</yamaha:X_yxcControlURL>
yamaha:X_yxcVersion1813 </yamaha:X_yxcVersion>
</yamaha:X_service>
</yamaha:X_serviceList>
</yamaha:X_device>
Damien is looking into whether multichannel DSD playback over UPnP to our Yamaha receiver or to our Sony UDP-X800 is possible. Both of these currently playback stereo DSD music (either .dsf files played or any stereo source upsampled to DSD) in Audirvana, sounding really good. In its Pure Direct mode, our Yamaha receiver playing DSD containing SOX-upsampled music from Audirvana approaches the sound quality of our high end Benchmark DAC. We can test this easily because we use the Benchmark as a pre-amp in both cases, using the same Classé amplifiers. Playing upsampled DSD from Audirvana to a home theater receiver holds a LOT of promise. It sounds way better than Airplay.
I found the following article in which someone says that playback of DSD over HDMI from a Mac or PC is impossible because it would require a hardware modification in the graphics subsystem that creates the HDMI signal. You may find it interesting:
Hi John, I don’t know if you’ve followed the in depth discussion, but to get back to your original question about great ways to play back DSD: In our mastering studio we have a high end Benchmark DAC which we feed upsampled DSD from Audirvana through a Sonore UltraRendu streamer (which is connected to the Benchmark DAC through an Uptone ISO Regen). I guess this is a high end setup and it sounds stunning.
Interestingly enough, we can also stream stereo DSD over the network to our Yamaha RX-A3060 home theater receiver over UPnP. This setup costs much less, but I can testify that stereo music upsampled to DSD by Audirvana and streamed to the receiver over UPnP sounds really good. Anybody who owns a DSD-capable receiver should definitely try it!
Hi mhsmit, did you get an answer from Damien? I have basically the same setup as you (Yamaha RX-A880 receiver and Sony UBP-X800 CD player) and would like to play my files on my Mac. Thanks.
Ok to be complete, I realized that Audirvana CANNOT stream (wirelessly) 5.1 multi channel. I verified this with Audirvana support.
So I ended up with the Exasound e38 DAC that does native DSD and their Sigma Streamer, plus Roon. (By native I mean no conversion to PCM or up sampling.) They work absolutely wonderfully and seamlessly. Love it. I was perfectly happy with Audirvana, but really wanted to be able to stream my library of ripped SACDs and multi channel downloads. Lack of this support on Audirvana was a deal breaker.
I also moved from Yamaha Aventage receivers to a Marantz 8012 because the Yamahas don’t have multi channel analog line inputs from the DAC to the receiver. (You’re not going to find a DAC that does native DSD over HDMI. Believe me, I tried. Marantz 7x/8x receivers all have analog multichannel inputs and don’t do any audio processing on between the signal path from the DAC to the speakers. I checked by looking at the circuit diagram in the service manual—I’m a computer scientist and electrical engineer.
So yes, it required revamping my setup, and required a bit more money than I was prepared to tell the wife about, but am very happy with it. She seems to be too, except for having to relearn the remote.
Hi there. Probably unforgivable, but for some reason, I’d entirely forgotten about this Thread and my question. But downloading the Audirvana Studio trial and then trying to get my head around having to commit to yet another Subscription model has concerned me and I’m poking 'round the Forum to get a feel for what’s going on.
So I’ve read the DAC DSD ideas above. For DSD files I’m presently using an SSL 2+ USB audio interface in PCM mode 192 kHz max but it downsized according to content. Sounds ok. I have quite a number of audio interfaces for recording mainly - as I’m a musician
Please keep your suggestion coming for DSD interfaces.
Thanks.
Hi there. I’ve only just checked in here (see my recent Post) but thanks guys for all the ideas.
