Thanks again.
I tried your suggestions. It made no difference. The debug info follows -
Audirvana Mac Version 3.5.34 (3564)
macOS 10.14.6 with 65536MB RAM
Registered to Stephen Ng
Sync list: 4 folders
AUTO: /Volumes/Digital_Music/HD_Tracks
AUTO: /Volumes/Digital_Music/Kerry
AUTO: /Volumes/Digital_Music/MyRIPs
AUTO: /Volumes/ThunderBay/Music/Music Purchased
Library database path: /Users/sng/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 62464MB
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Active Sample Rate: 192kHz
ID 0x53 iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0x54 2 channels starting at 1
16 virtual formats:
16 physical formats
Device #0: ID 0x53 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Device #1: ID 0x47 iMac Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 DMR-BWT955 UID: uuid:4D454930-0300-1000-8000-80C7552AA6D7 Location: http://10.0.0.3:60607/80C7552AA6D7/Server1/ddd
