Windows A+ Volume Control
Hi
Has volume control been implemented in A+ for windows ? For example running a DAC with no volume control directly from A+ there is no way to control the volume. I have the mac A+ and you can control volume from the A+ software.
Bob
This will come in the 1.4 update, scheduled for January.
FYI, I’m going to release the 1.3 today that brings the VST3 plugins support.
Waiting for the 1.4 you can use any VST3 (free) plugin that provides a gain/volume control (e.g. any EQ one), and activate the realtime setup of the plugin.
merci beaucoup Damien
I am using Windows Audirvana and the volume slider has no effect on my system (DAC/Pre/Amp). Any idea what’s up?
Hi Damien,
I am using Audirvana 3.5.3 on a Windows 10 PC.
Yesterday, I have switched on the volume control on the software, in order to set at 0db the volume level of my Classe 2200i network player/DAC/amplifier.
Both on my PC and on my IPad, the bar of the volume level of the software always shows max level.
As a result, when I want to change the volume, I have to put my finger where the bar is, ie max volume, and the sound instantly jumps to max volume (which is very dangerous for my speakers).
How can I solve this?
I would suggest too to add a « startup volume » to avoid any surprise.
Thank you for your help.
Hello @zephyr58, before you put the volume control, did you put the volume of your DAC to the maximum level you want?
Yes, Damien, the volume level was at “0 db”.
But I am quite bothered today : I have tried to “replay” the trouble, and the software reaction is quite different:
  • I have set the software max level at about 50% (it could be nice to have a more precise scale on the bar),
  • I have set my Classe Amp/DAC at max level I have authorized, ie -25db.
Of course, the button “software volume control” is on.
But, when using Audirvana Remote on IPad, the volume on the screen of the Classe is moving : -45db (for instance), …up to -25 db (the maximum level I have authorized).
So, it seems that the volume of the DAC is still active.
Am I doing something wrong?
Hi Damien,
please find hereunder the requested information:
Audirvana 3.5.3
Phase = 73
Max allowed volume: 51.3817
SW volume control: ON
Manual: (OFFLINE) Z:
Library database path: C:\Users\Mistr\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Sigma 2200i 22A63D Model UID:B&W Group Ltd Sigma 2200i 22A63D UID:uuid:5f9ec1b3-ed59-1900-4530-d81ede000000
Currently playing to UPnP device at 24 bits 88.2kHz
UPnP device at http://192.168.0.153:8080/description.xml
Sigma 2200i 22A63D Manufacturer:B&W Group Ltd
Volume control: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-wavetunes:
:audio/x-ms-wma:*
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get::audio/x-caf:
http-get::audio/x-aiff:
http-get::audio/aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
2 ch Integer PCM 24bit big endian 44.1kHz
2 ch Integer PCM 16bit big endian 88.2kHz
2 ch Integer PCM 24bit big endian 88.2kHz
2 ch Integer PCM 24bit big endian 48kHz
2 ch Integer PCM 16bit big endian 96kHz
2 ch Integer PCM 24bit big endian 96kHz
NrTracks: 1
MediaDuration: 0:09:07
CurrentURI: http://192.168.0.220:49152/audirvana/audio_0_8.aif
CurrentURIMetadata:
dc:titleSo What</dc:title>
dc:creatorMiles Davis</dc:creator>
upnp:artistMiles Davis</upnp:artist>
upnp:genreJazz</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/78/07/0886444350778_600.jpg</upnp:albumArtURI>
upnp:albumKind Of Blue</upnp:album>
nextURI: http://192.168.0.220:49152/audirvana/audio_1_9.aif
My Way Nina Simone Nina Simone Jazz http://static.qobuz.com/images/covers/uc/ka/k2xujawbikauc_600.jpg Nina Simone - Nina 9 object.item.audioItem.musicTrack http://192.168.0.220:49152/audirvana/audio_1_9.aif
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions LastChange string TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:1 SeekOnPaused,WHA urn:schemas-upnp-org:device:MediaRenderer:1 Sigma 2200i 22A63D B&W Group Ltd Sigma Integrated Amplifier Sigma 2200i Sigma 2200i D81EDE22A63D uuid:5f9ec1b3-ed59-1900-4530-d81ede000000 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-smsc-com:service:X_WholeHomeAudio:1 urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl urn:tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.0.153
UPnP devices found : 1
Device #0Sigma 2200i 22A63D UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede000000 Location: http://192.168.0.153:8080/description.xml
Max. memory for audio buffers: 2172MB
Local Audio Engine:ASIO 1634296890 driver version 1009859180
Device #0: JRiver Media Center 25 Manufacturer: Model UID: JRiver Media Center 25 UID: JRiver Media Center 25
