Hello, I have a problem with the volume control. Audirvana does not allow you to control the volume from the Windows system menu. The control can be performed only by the Audirvana.
I want to be able to control from the main menu of Windows .
Audirvana 3.5.45
Replay Gain: by album
SW volume control: ON
Sync list: 2 folders
AUTO: F:\123\Convert
AUTO: F:\Famoust ARTIST
Library database path: C:\Users\sony vai\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 7148MB
Local Audio Engine:WASAPI
JPLAY Driver
Model UID:JPLAY Driver
UID:JPLAY Driver
Active Sample Rate: 192kHz
SPDIF Interface (North Star Design USB Hi-Speed interface (1.0.3)) Manufacturer:
Model UID:SPDIF Interface (North Star Design USB Hi-Speed interface (1.0.3)) UID:?\SWD#MMDEVAPI#{0.0.0.00000000}.{93ea75ef-95c9-4080-88b9-14e0da018e9a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: SPDIF Interface (North Star Design USB Hi-Speed interface (1.0.3)) Manufacturer: Model UID: SPDIF Interface (North Star Design USB Hi-Speed interface (1.0.3)) UID: ?\SWD#MMDEVAPI#{0.0.0.00000000}.{93ea75ef-95c9-4080-88b9-14e0da018e9a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (High Definition Audio Device) Manufacturer: Model UID: Speakers (High Definition Audio Device) UID: ?\SWD#MMDEVAPI#{0.0.0.00000000}.{edd82a91-8538-43cf-9fbf-243c1944d9cb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Тhank you in advance!
