Zoom function
The Zoom change can be automatically seen in the app, and the zoom will be applied to every view where you see a cover:
This is a quote from the”How to zoom in Audirvāna?” Instructions.
However when in Search Results >Albums that function is locked. It appears that one needs to bring up a Playlist, this opens the Zoom and change of album size is possible. Return to Search Results >Albums and the Zoom setting set for Playlists is maintained. Sadly though the Search Results >Albums reverts to the first album and a lengthy scroll may result.
Hopefully I have got this wrong and a simple solution may surface
When you get search results, select the album cover that you wish to resize.
Respectfully,this is not the solution to the problem I outlined above. Choosing one album in the search result will not allow for any forward zoom of other albums in the search result nor does it address the problem where any adjustment means the search result reverts to to start position. Try that with a search of say Mozart in Presto and you may have over 1000 albums to scroll to regain your position in the search
When in ‘Local’ folder view, the titles in a folder are zoomable…
It seems to me that if you are looking for Mozart album, this would be best done on the Presto Music site and subsequently add the title to your library…
