I’m getting this error “can’t switch to Integer mode” with 2.2.2.0. With the previous version I could not use kernel mode at all as some sample rates were greyed out. Now with 2.2.2.0 that is fixed but I can’t play anything without getting that message. Log attached below.
Audirvana Studio 2.2.2 (20202)
Windows 11 (22000) with 16GB physical RAM
Connected account of : Brandon Parker
Sync list: 2 folders
AUTO: \Frontwave\MUSIC
AUTO: C:\MUSIC
Library database path: C:\Users\Brandon\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 172.16.0.48 on port 50938
Max. memory for audio buffers: 3494MB
1 - AVM 90 (2- AMD High Definition Audio Device)
Model UID:HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1007
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e14e7cf3-0663-49a4-936f-7f95663d910e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:1 - AVM 90 (2- AMD High Definition Audio Device)
Manufacturer: Advanced Micro Devices
Model UID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1007
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e14e7cf3-0663-49a4-936f-7f95663d910e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
8 ch Integer PCM 16bit little endian 44.1kHz
8 ch Integer PCM 24bit little endian 44.1kHz
8 ch Integer PCM 16bit little endian 48kHz
8 ch Integer PCM 24bit little endian 48kHz
8 ch Integer PCM 16bit little endian 88.2kHz
8 ch Integer PCM 24bit little endian 88.2kHz
8 ch Integer PCM 16bit little endian 96kHz
8 ch Integer PCM 24bit little endian 96kHz
8 ch Integer PCM 16bit little endian 176.4kHz
8 ch Integer PCM 24bit little endian 176.4kHz
8 ch Integer PCM 16bit little endian 192kHz
8 ch Integer PCM 24bit little endian 192kHz
Device #0: Speakers (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0897&SUBSYS_1022C950&REV_1004
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{cc2e8d3d-62e9-4297-aded-01fca6451917}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: 1 - AVM 90 (2- AMD High Definition Audio Device)
UPnP devices found : 1
Device #0: AVM 90-42291E
UID: uuid:b83a635e-6e38-4b40-aa87-29e5d46c004b
Location: http://172.16.0.28:38507/b83a635e-6e38-4b40-aa87-29e5d46c004b.xml
Manufacturer: Anthem
Model name: AVM 90
Chromecast devices found : 2
Device #0: RV
Model name: HiSmart 4K ATV4
Device #1: AVM 90-42291E
Model name: AVM 90
