2.6.6 is crashing with regularity. Upon program launch none of my albums are available. I can select the tracks view, but then the program terminates. The log is included, below:
Process: Audirvana Plus [850]
Path: /Applications/Audirvana Plus.app/Contents/MacOS/Audirvana Plus
Identifier: com.audirvana.Audirvana-Plus
Version: 2.6.6 (2.6.6)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Audirvana Plus [850]
User ID: 501
Date/Time: 2017-09-04 15:55:47.765 -0400
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: 4D643EFB-9AF3-8FE6-84B3-E70342EBCCB0
Time Awake Since Boot: 890 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.audirvana.sqlQueue
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0:
ā>
__TEXT 0000000100000000-0000000100aa8000 [ 10.7M] r-x/rwx SM=COW /Applications/Audirvana Plus.app/Contents/MacOS/Audirvana Plus
Thread 0 Crashed:: Dispatch queue: com.audirvana.sqlQueue
0 libswiftCore.dylib 0x00000001016c1201 swift::_swift_getClass(void const*) + 33
1 com.audirvana.Audirvana-Plus 0x00000001002a10e7 0x100000000 + 2756839
2 com.audirvana.Audirvana-Plus 0x000000010086d80c 0x100000000 + 8837132
3 com.audirvana.Audirvana-Plus 0x000000010088c758 0x100000000 + 8963928
4 com.audirvana.Audirvana-Plus 0x000000010085cace 0x100000000 + 8768206
5 com.audirvana.Audirvana-Plus 0x00000001000badb4 0x100000000 + 765364
6 com.audirvana.Audirvana-Plus 0x00000001002afa5f 0x100000000 + 2816607
7 com.audirvana.Audirvana-Plus 0x00000001002afcab 0x100000000 + 2817195
8 com.audirvana.Audirvana-Plus 0x00000001002afbff 0x100000000 + 2817023
9 libdispatch.dylib 0x00007fff925658fc _dispatch_client_callout + 8
10 libdispatch.dylib 0x00007fff92566536 _dispatch_barrier_sync_f_invoke + 83
11 com.audirvana.Audirvana-Plus 0x00000001002a524c 0x100000000 + 2773580
12 com.audirvana.Audirvana-Plus 0x00000001004be921 0x100000000 + 4974881
13 com.audirvana.Audirvana-Plus 0x00000001004bea76 0x100000000 + 4975222
14 com.audirvana.Audirvana-Plus 0x00000001005f90ef 0x100000000 + 6263023
15 com.audirvana.Audirvana-Plus 0x000000010022bf03 0x100000000 + 2277123
16 com.audirvana.Audirvana-Plus 0x000000010022bba5 0x100000000 + 2276261
17 com.apple.CoreFoundation 0x00007fff7c9ee54c CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER + 12
18 com.apple.CoreFoundation 0x00007fff7c9ee44b _CFXRegistrationPost + 427
19 com.apple.CoreFoundation 0x00007fff7c9ee1b2 ___CFXNotificationPost_block_invoke + 50
20 com.apple.CoreFoundation 0x00007fff7c9ac782 -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 2018
21 com.apple.CoreFoundation 0x00007fff7c9ab76b _CFXNotificationPost + 667
22 com.apple.Foundation 0x00007fff7e3ed677 -[NSNotificationCenter postNotificationName:object:userInfo:] + 66
23 com.apple.AppKit 0x00007fff7a6735e9 -[NSTableView _sendSelectionChangedNotificationForRows:columns:] + 175
24 com.apple.AppKit 0x00007fff7a5dafd1 -[NSTableView _enableSelectionPostingAndPost] + 401
25 com.apple.AppKit 0x00007fff7a5dc034 -[NSTableView _doSelectIndexes:byExtendingSelection:indexType:funnelThroughSingleIndexVersion:] + 3189
26 com.audirvana.Audirvana-Plus 0x0000000100234a05 0x100000000 + 2312709
27 com.audirvana.Audirvana-Plus 0x0000000100234927 0x100000000 + 2312487
28 com.audirvana.Audirvana-Plus 0x0000000100221ac0 0x100000000 + 2235072
29 com.audirvana.Audirvana-Plus 0x00000001006108af 0x100000000 + 6359215
30 com.audirvana.Audirvana-Plus 0x00000001004c1248 0x100000000 + 4985416
31 com.audirvana.Audirvana-Plus 0x00000001004bfe3f 0x100000000 + 4980287
32 com.audirvana.Audirvana-Plus 0x000000010016ec89 0x100000000 + 1502345
33 com.audirvana.Audirvana-Plus 0x000000010016ee2a 0x100000000 + 1502762
34 com.apple.CoreFoundation 0x00007fff7c9ee54c CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER + 12
35 com.apple.CoreFoundation 0x00007fff7c9ee44b _CFXRegistrationPost + 427
36 com.apple.CoreFoundation 0x00007fff7c9ee1b2 ___CFXNotificationPost_block_invoke + 50
37 com.apple.CoreFoundation 0x00007fff7c9ac782 -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 2018
38 com.apple.CoreFoundation 0x00007fff7c9ab76b _CFXNotificationPost + 667
39 com.apple.Foundation 0x00007fff7e3ed677 -[NSNotificationCenter postNotificationName:object:userInfo:] + 66
40 com.apple.AppKit 0x00007fff7a6735e9 -[NSTableView _sendSelectionChangedNotificationForRows:columns:] + 175
41 com.apple.AppKit 0x00007fff7a5dafd1 -[NSTableView _enableSelectionPostingAndPost] + 401
42 com.apple.AppKit 0x00007fff7a7a80f8 -[NSTableView mouseDown:] + 6392
43 com.apple.AppKit 0x00007fff7adca24f -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 6341
44 com.apple.AppKit 0x00007fff7adc6a6c -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1942
45 com.apple.AppKit 0x00007fff7adc5f0a -[NSWindow(NSEventRouting) sendEvent:] + 541
46 com.apple.AppKit 0x00007fff7ac4a681 -[NSApplication(NSEvent) sendEvent:] + 1145
47 com.apple.AppKit 0x00007fff7a4c5427 -[NSApplication run] + 1002
48 com.apple.AppKit 0x00007fff7a48fe0e NSApplicationMain + 1237
49 libdyld.dylib 0x00007fff9259b235 start + 1
Thread 1:: Dispatch queue: com.apple.root.default-qos
0 libsystem_kernel.dylib 0x00007fff926c2386 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff9257da77 _os_semaphore_wait + 16
2 libdispatch.dylib 0x00007fff9256e891 _dispatch_semaphore_wait_slow + 103
3 com.audirvana.Audirvana-Plus 0x00000001009b27e3 0x100000000 + 10168291
4 libdispatch.dylib 0x00007fff9256e524 _dispatch_call_block_and_release + 12
5 libdispatch.dylib 0x00007fff925658fc _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fff925741f4 _dispatch_queue_override_invoke + 837
7 libdispatch.dylib 0x00007fff925676b5 _dispatch_root_queue_drain + 476
8 libdispatch.dylib 0x00007fff9256748c _dispatch_worker_thread3 + 99
9 libsystem_pthread.dylib 0x00007fff927b45a2 _pthread_wqthread + 1299
10 libsystem_pthread.dylib 0x00007fff927b407d start_wqthread + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff926c234a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff926c1797 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff7c9d9874 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff7c9d8cf1 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fff7c9d8544 CFRunLoopRunSpecific + 420
5 com.apple.CoreFoundation 0x00007fff7ca17d31 CFRunLoopRun + 97
6 com.apple.Foundation 0x00007fff7e4198ad NSThread__start + 1243
7 libsystem_pthread.dylib 0x00007fff927b493b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fff927b4887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fff927b408d thread_start + 13
Thread 3:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff7a61df02 _NSEventThread + 205
6 libsystem_pthread.dylib 0x00007fff927b493b _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fff927b4887 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fff927b408d thread_start + 13
Thread 4:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff926c9eb6 __select + 10
1 com.apple.CoreFoundation 0x00007fff7ca14939 __CFSocketManager + 729
2 libsystem_pthread.dylib 0x00007fff927b493b _pthread_body + 180
3 libsystem_pthread.dylib 0x00007fff927b4887 _pthread_start + 286
4 libsystem_pthread.dylib 0x00007fff927b408d thread_start + 13
Thread 5:
0 libsystem_kernel.dylib 0x00007fff926ca44e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff927b448e _pthread_wqthread + 1023
2 libsystem_pthread.dylib 0x00007fff927b407d start_wqthread + 13
Thread 6:
1 libsystem_pthread.dylib 0x00007fff927b4621 _pthread_wqthread + 1426
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007ffffffffff8 rbx: 0x0000000000000000 rcx: 0x00000001002a10d0 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000008 rbp: 0x00007fff5fbfc470 rsp: 0x00007fff5fbfc468
r8: 0x0000000104f5a800 r9: 0x0000000000008004 r10: 0x0000000000000018 r11: 0x0000000000000206
r12: 0x000000010700f800 r13: 0x0000000102014da0 r14: 0x0000000000000001 r15: 0x0000000000000002
rip: 0x00000001016c1201 rfl: 0x0000000000010246 cr2: 0x0000000000000000
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
