I am using blue tooth to stream music off my Ayon S3 streamer dac, When I play Tidal 24 bit music it starts and stops and starts again. How can I fix this issue?
Have you tried to reduce the pre-load cache? Can you paste the debug info here?
Audirvana Mac Version 3.5.46 (3576)
macOS 11.5.1 with 8192MB RAM
Registered to William F ODonnell
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Mon Apr 26 08:44:24 2021
Library database path: /Users/williamodonnell/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: ayon S-3 Model UID:ayon ayon S-3 UID:uuid:5F9EC1B3-FF59-19BB-8530-0011F68BADB9
Currently playing to UPnP device at 24 bits 88.2kHz
UPnP device at http://10.0.0.34:8080/description.xml
ID 0x0 ayon S-3 Manufacturer:ayon
Volume control: No
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=192000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=192000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=192000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=192000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/x-mpeg:
http-get::audio/mpeg:
http-get::audio/mpegurl:
http-get::audio/x-mpegurl:
http-get::audio/scpls:
http-get::audio/ms-wma:
http-get::audio/x-ms-wma:
http-get::application/octet-stream:
http-get::audio/x-ms-asf:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-wav:
http-get::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:03:39
CurrentURI: http://10.0.0.30:49152/audirvana/audio_0_5.mqa.wav
CurrentURIMetadata: dc:titleMy Baby Just Cares for Me</dc:title>upnp:artistLedisi</upnp:artist>upnp:albumLedisi Sings Nina</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/c4fc59fb/bf2b/4a06/ad84/98e853d70192/640x640.jpg</upnp:albumArtURI>http://10.0.0.30:49152/audirvana/audio_0_5.mqa.wav
nextURI: http://10.0.0.30:49152/audirvana/audio_1_6.mqa.wav
nextURIMetadata:
dc:titleNe Me Quitte Pas (Don’t Leave Me)</dc:title>
dc:creatorLedisi</dc:creator>
upnp:genre</upnp:genre>
upnp:originalTrackNumber3</upnp:originalTrackNumber>
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 Multimedia.DMR BridgecoCE2DM870_0xBD urn:schemas-upnp-org:device:MediaRenderer:1 ayon S-3 ayon http://www.ayonaudio.com High End Streaming Client ayon S-3 1.0 http://www.ayonaudio.com/ 0011F68BADB9 uuid:5F9EC1B3-FF59-19BB-8530-0011F68BADB9 123810928305556upc image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt urn:schemas-dm-holdings-com:service:X_WholeHomeAudio:1 urn:schemas-dm-holdings-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl /WholeHomeAudio/evt http://10.0.0.34UPnP devices found : 1
Device #0: ID 0x0 ayon S-3 UID: uuid:5F9EC1B3-FF59-19BB-8530-0011F68BADB9 Location: http://10.0.0.34:8080/description.xml
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:51 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Set the pre-load cache to 2000MB.
Does your device is MQA compatible?
