Hello,
after updating to 3.5.33, I noticed that Audirvana no longer plays whole albums when streaming from Qobuz, but only single tracks, or in case of an albums with (eg.) two symphonies, only one symphony at a time.
Please see below for debug info.
Kind regards,
Dieter
Audirvana Mac Version 3.5.33 (3563)
macOS 10.15.3 with 16384MB RAM
Registered to Dieter Schwaller
AUTO: /Volumes/Musik/Dieter’s Musik/iTunes/iTunes Media/Music
Library database path: /Users/dieterjp/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:14200000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 384kHz
Active Sample Rate: 384kHz
Hog Mode is on
ID 0xca iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:14200000:1
Audio buffer frame size : 116 to 4096 frames
Stream ID 0xcb 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 4
Device #0: ID 0xc2 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0xca iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:14200000:1
Device #2: ID 0x29 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #3: ID 0x34 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
