Running the latest version of Audirvana, 3.5.44. Every time I try to synchronize with Tidal, it does so but opens up Audirvana Plus version 3.2.20 instead. What am I doing wrong? Do I need to delete Audirvana Plus from my laptop?
Yes, you need to remove the old version.
or keep it elsewhere… then trash the old one in applications folder.
Thanks guys, just removed the old version and problem solved.
