What are the differences between the new 3.5 and Origin as far as the interface is concerned? I can’t try it out, as it’s telling me that there is no trial option. I am currently on the Origin trial.
My two cents on Audirvana.
There needs to be a way to go with larger fonts. Two settings is not enough. I have MC31, and I can go as high as 400%. On a computer or laptop, that works, but on a big screen sitting 12 feet away, it doesn’t.
It’s good that Audirvana can use Audio Units, but having these windows floating around is not exactly polished. I have to switch between windows to use the EQ or any other effect. These effects should be accessible from a button on the main view and it should fill the area where the Album Info is at.
The Lock Button should be inside the Preferences, so that one does not have to be going in and out of the preferences. It’s easy when you are in front of a computer or in a laptop, but on a large screen with a bluetooth keyboard it is very cumbersome.
If it’s not enough for you, then I strongly recommend you to try the Audirvāna Remote app, you can use for free on a iOS or Android device.
You have the choice to display them or not. You need to disable the real time mode and it won’t be displayed when you play your track but the effect will be applied:
