I replaced a 2014 Mac mini with a new one with Apple Silicon (M1) processor. Audirvana run, but it doesn’t properly detect my Marantz AV receiver that’s connected via HDMI. It want to treat it as a 24-bit 768KHz device, but (according to Audio-MIDI-Setup and past experience) it only supports 48KHz.
The result is that during playback I hear something, but not the actual music,
Here’s the debug output:
macOS 10.16.0 with 16384MB RAM
Registriert nach Sebastian Hagedorn
AUTO: /Users/a0620/Music/Multichannel Music
iTunes/Music library synchronization: last synchronized on Wed Jun 24 07:18:02 2020
Library database path: /Users/a0620/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Exclusive access: Disabled
HDMI
Model UID:AppleHDA:108
UID:AppleHDAEngineOutputDP:3,0,1,1:0:{4935-002C-01010101}
Active Sample Rate: 48kHz
ID 0x33 marantz-AVR Manufacturer:MJI
Model UID:35492C00-0000-0000-0017-0103808E5078 UID:35492C00-0000-0000-0017-0103808E5078
7 available sample rates up to 768000Hz
32000
Audio buffer frame size : 15 to 2304 frames
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 3
Channel 3 mapped to 2
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x34 8 channels starting at 1
7 virtual formats:
3 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
5 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
7 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
21 physical formats
3 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
7 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
7 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
4 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
5 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
7 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
Device #0: ID 0x33 marantz-AVR Manufacturer: MJI Model UID: 35492C00-0000-0000-0017-0103808E5078 UID: 35492C00-0000-0000-0017-0103808E5078
Device #1: ID 0x2d Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP not started
