Hello.
I have a few problems with audirvana studio.
The amplifier I use is NT-505 of teac.
This is a network player.
When I connect with usb, it plays well without interruption, but when I connect with a network (wifi) player, I can’t hear it because it’s disconnected.
In other programs, for example, roon, linn kazoo, it plays well without interruption.
However, I like audirvana and want to use it, but this issue is a problem. I would like to know if there is any possibility of improvement.
Why didn’t he get an answer? I have the same problem.
You have an TEAC NT-505 as well ? Perhaps you could post your debug info as we have no idea what OS or computer and audio equipment you have ?
Have you tried to change the “send as raw PCM” flag in the settings?
Hi,
I apologize for not providing complete information. Today I downloaded the Trial version of Audrivana Studio. So far, I use the latest version of Audirvana Plus for Mac. On audirvana Plus, everything worked without problems, playback (streaming) over the uPnP network. Audirvana Studio sees both Simaudio Moon and Denon network players but can’t start playback. I also add Debug info.
Audirvana Studio 1.8.5 (10805)
macOS Version 11.6 (Build 20G165) with 8GB physical RAM
Sync list: 2 folders
AUTO: /Volumes/music/
AUTO: /Users/alexanderhauskrecht/Music
iTunes/Music library synchronization: last synchronized on Mon Dec 6 10:43:58 2021
Library database path: /Users/alexanderhauskrecht/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52158
Preferred device: SIMAUDIO 280D MIND 2 LIVING ROOM Model UID:Simaudio 280D MiND 2 Living Room UID:uuid:07f5febb-f99d-4a7b-808a-ef8574145361
UPnP device at http://192.168.0.67:33953/07f5febb-f99d-4a7b-808a-ef8574145361.xml
ID 0x0 280D MiND 2 Living Room
Manufacturer: Simaudio
Model Name:
Model UID: Simaudio 280D MiND 2 Living Room
UID: uuid:07f5febb-f99d-4a7b-808a-ef8574145361
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: Yes
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/wave:
http-get::audio/x-flac:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::application/ogg:
http-get::audio/x-dsd:
http-get::text/xml:
http-get::audio/flac:
http-get::audio/x-dsf:
http-get::audio/ogg:
http-get::audio/x-dff:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/x-aiff:
http-get::audio/aac:
http-get::audio/dsd:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-dsd:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/dsd:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
26 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 280D MiND 2 Living Room Simaudio http://www.simaudio.com/ MiND 2 MOON 280D 000000 http://www.simaudio.com/ 501E2D3688E8 uuid:07f5febb-f99d-4a7b-808a-ef8574145361 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.0.67:80/ DMR-1.51UPnP devices found : 2
Device #0: ID 0x0 Denon AVR-X3100W UID: uuid:5f9ec1b3-ff59-19bb-8530-0005cd41e7c2 Location: http://192.168.0.10:8080/description.xml
Device #1: ID 0x0 280D MiND 2 Living Room UID: uuid:07f5febb-f99d-4a7b-808a-ef8574145361 Location: http://192.168.0.67:33953/07f5febb-f99d-4a7b-808a-ef8574145361.xml
Device #0: ID 0x4d Reproduktory MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Reproduktory MacBook Pro
Good deal that may help, as @bitracer recommends try the pcm- raw switch. That’s what my Oppo205 needs to do UPNP
Perhaps move your buffer down to 4000 mb especially as you have 8 gb memory
so I had the pcm-raw switch turned on after its recommendation, but it didn’t play without change. Now I have reduced the buffer to 4GB and it is already working. My streamer is already playing music.
So I don’t know if it’s just cutting the buffer in half compared to my 8GB of RAM on my MacBook or something else. Nevertheless, I want to thank you for your efforts and help.
Have a nice day
That’s brilliant, have a good time with your system and your music.
thanks
