Hi,
Is there a way to search for MQA files via the Remote app?
Or will there be an updated app for Audirvana 3 ?
Hi,
You can find MQA Albums in Tidal New>Masters in Remote. It is the same as destop version. No upgrade is needed.
I am noticing on my iPad not all of the Tidal Masters albums does not populate. Is there a fix for this?
