Hi @Antoine, here it is:
Audirvana Mac Version 3.5.32 (3562)
macOS 10.15.4 with 16384MB RAM
Licence enregistrée pour Kévin PIQUEMAL
Per track: OFF
AU plugin #0: Effect - Waves Abbey Road Studio 3 (6->2) ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Users/kevinpiquemal/Music/iTunes/iTunes Media
Library database path: /Users/kevinpiquemal/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1402MB
Écouteurs externes
Model UID:Codec Output
UID:BuiltInHeadphoneOutputDevice
Active Sample Rate: 96kHz
ID 0x4b Écouteurs externes Manufacturer:Apple Inc.
Model UID:Codec Output UID:BuiltInHeadphoneOutputDevice
Stream ID 0x4c 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x4b Écouteurs externes Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice
Device #1: ID 0x56 Haut-parleurs MacBook Air Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
