Ability to delete tracks from Qobuz playlists?
I’m currently evaluating Audirvana as a Roon replacement. So far, the only potential deal-breaker is that the Remote app (Android) doesn’t appear to have a way to delete tracks from Qobuz playlists (which is possible on the desktop app).
Does anyone know if this functionality will be added or if there’s some reason why it’s not possible?
It is a good idea and it would not surprise me if it is added in the future. But… you may want to ask that to [email protected].
I’m using Mac & IOS Remote with Tidal, but have had Qobuz playlist previously. If you open the Playlist on the remote. click the 3 dots, select edit track, you will get the tracks showing with a circle to the far left, click to select tracks,amd hit the delete button at the bottom far right.
Forget that you then have to hit OK up in the top right corner.
Hi @jluce50 , from what I see, it seems there is a bug in the Android version, as if you click on the three-dot button of the playlist and slide on the track to remove it, the track disappears, but there is like a refresh bug going on we need to tackle here.
Ah, that would explain it then. Thanks for the heads up!
