About the Connection with external Audio Devices category
(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters.)
Use the following paragraphs for a longer description, or to establish category guidelines or rules:
  • Why should people use this category? What is it for?
  • How exactly is this different than the other categories we already have?
  • What should topics in this category generally contain?
  • Do we need this category? Can we merge with another category, or subcategory?
I would appreciate your help, I am trying to play Audirvana 3.5.44, through a Macmini and an Oppo 205, for the USB DAC connection and I can’t get it to work. Please could you tell me what is failing me in the configuration so that it does not work. Of course in the Audirvana settings I have the Oppo assigned in audio preferences. Thanks
