Hi!
I found a bug in 3.5.40!
Albums stating with a ( or ) as Album name ( for Example ‘(Still) Heartless’ ) won’t be added to library. Removing ( or ) in album name will solve the problem and the album is properly added to library.
Hi!
Hello @VonBrechts, are you using Audirvana for Windows 10 or MacOs? What is the path of the folder you want to add in Audirvana?
Hi!
I’m using Audirvana for Win 10 and the Path is “Z:”, a mapped NAS
My library contains almost 7000 Albums, all in .aiff format, tagged and ripped with dbpoweramp or downloaded at qobuz etc.
I figured out that albums starting with a sign instad of a letter or number won’t be added to library.
I have deleted the .sqlite database and creating a new two times library to get sure of the problem.
