i am using an i mac as server.
Audirvana finds the Yamaha RN 303 D but not the T+A Cala.
All devices in the same network
Need help
Need help
Hello @markusw,
Do you have a Network mode in your Cala settings? if you choose this source mode, do you see your Cala in Audirvana?
Hi,
thank you for asking.
No I dont See the Malaiin the app.
sorry i ment to say i don`t see the T+A cala in the app.
The T+A cala says no server found.
That’s normal, Audirvana is not an UPnP server. Have you tried from Audirvana if it can see the Cala.
Audirvana can not See the cala
Can you try to to download JRiver and test with that.
i can do that but what is JRiver?
So River Looks like another Media center.
The Cala already worked with universal media server and twonky server.
But i would like to get Audirvana running.
It was just to check if you can stream to Cala from JRiver. It’s also possible that Cala is not compatible with Audirvana. Can you dump the debug info here?
ihm sorry but ii dont know how
The Debugger Info
Audirvana Mac Version 3.5.41 (3571)
macOS 10.15.7 with 12288MB RAM
Die Testversion verwendet eine Demo-Lizenz
AUTO: /Volumes/LaCie-2big-4TB/Audio LC-2big/iTunes High Res
Library database path: /Users/markuswirth/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 9216MB
Ausgang (integriert)
Model UID:AppleHDA:7
UID:AppleHDAEngineOutput:1B,0,1,2:0
Hog Mode is on
ID 0x2f Ausgang (integriert) Manufacturer:Apple Inc.
Model UID:AppleHDA:7 UID:AppleHDAEngineOutput:1B,0,1,2:0
Stream ID 0x30 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x2f Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1B,0,1,2:0
UPnP devices found : 1
Device #0: ID 0x0 R-N303D 86571F UID: uuid:9ab0c000-f668-11de-9976-00a0de86571f Location: http://192.168.178.43:49154/MediaRenderer/desc.xml
I think you might ask T+A if the Cala is compatible with media renderer software.
Do i need a special render software ?
With other Programms like unniversel media server or twonky server i can use the CALA.
I realy want to use Audirvana but it looks like it`s a bit complicated.
Those software are UPnP media server software. This is why you can play your file with them to your Cala. There is a difference between UPnP server and media renderer, this is why you need to ask T+A about this compatibility.
