Again! Settings with MathAudio-RoomEQ don’t seem to stick :-(
Audirvana 3.1.0
Windows 11
MathAudio-RoomEQ 2.8.5
Settings done via »Configure« may look like this:
»Save« pressed, and after pressing »Configure« once again:
This sucks !!!
Hi @Audi100 , when you save the preset, does it save it into a file in the plugin?
Yes.
Do you see the file modified date being updated when you save the preset?
Are we talking the same thing? When saving a MathAudio-Room-EQ Preset I get a window to specify name and location, and the saved file has an .snr extension. And of course its modification date is updated after saving.
Ok, then I need to do further testing on my end.
@Audi100 , Can you send me your snr file at [email protected]?
Sent!
I get some bips when I use the plugin with your SNR file. Is this normal?
You may hear beeps if your version of MathAudio Room-EQ is not registered.
