When I scan my AIFF music, I notice there’s a coding issue in the Bit Depth field and there are DC issues also. I’m puzzled as to why. The same song in Wav format has no such problem. I convert my CDs and digitally bought music with dbPoweramp.
Hi! I’ve sent you the file on november 16th as a Proton Drive link since it was too big to send in email. Did you received it? Thanks!
Yes, I received the file but couldn’t come back to you earlier, will try to look at it as soon as possible.
Perfect. No worries. I was just wondering if the file went through. Thank you.
