I have an Advance Paris play stream A5 receiver with a Wolfson Dac WM8720, When I play files 24 bits files With Audirvana it stops playing it stops after a few seconds with this settings.
Does anybody know what the problem is?
This is the debug info.
Audirvana Origin 2.5.13 (20513)
macOS Version 14.5 (Build 23F79) with 16GB physical RAM
Connected account of : John van der Hulst
Bandwidth = 87.9931%
Max allowed volume: 61.7661
SW volume control: ON
AUTO: /Users/johnvanderhulst/Desktop/Muziek
iTunes/Music library synchronization: last synchronized on Tue May 28 10:44:43 2024
Library database path: /Users/johnvanderhulst/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 59028
Font size: regular
Language: English
My Music
Library
Startup view: My Playlists
Use Apple Remote: no
Number of paired remotes: 2
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] A5_7B72 Model UID:wiimu A5 UID:uuid:FF31f0A7-7DFF-F91C-C213-1ADFFF31f0A7
Currently playing to UPnP device at 16 bits 44.1kHz
Selected device:A5_7B72
Manufacturer: wiimu
Model name: A5
Model UID: wiimu A5
UID: uuid:FF31f0A7-7DFF-F91C-C213-1ADFFF31f0A7
UPnP device at http://192.168.178.17:49152/description.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
DSD via PCM 1.1
UPnP set capabilities
Maximum PCM bitdepth set: 16
Not native DSD capable
Avoid RAW PCM streams: Yes
Unwanted playback stop workaround: Yes
http-get::audio/wav:DLNA.ORG_PN=LPCM
http-get::audio/x-wav:DLNA.ORG_PN=LPCM
http-get::audio/mpeg:DLNA.ORG_PN=MP2_MPS
http-get::audio/mp3:
http-get::audio/wma:
http-get::audio/m4a:DLNA.ORG_PN=AAC_ISO
http-get::audio/aac:DLNA.ORG_PN=AAC_ISO
http-get::audio/ac3:DLNA.ORG_PN=AC3
http-get::audio/ogg:*
http-get::audio/ape:
http-get::audio/x-ape:
http-get::audio/flac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
10 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 03:22:53
CurrentURI: http://192.168.178.38:49152/audirvana/gaplessAudio_f_4.wav
CurrentURIMetadata:
dc:titleAudirvana gapless playback</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: THIRD-DLNA
Current transport actions:
Stop,Seek,X_DLNA_SeekTime,Pause
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 A5_7B72 wiimu http://www.wiimu.com/ WiiMu LinkPlayer WiiMu LinkPlayer http://www.muzohifi.com/ uuid:FF31f0A7-7DFF-F91C-C213-1ADFFF31f0A7 V01-Mar 5 2021 00001 A5_7B72 FF31f0A77DFFF91CC2131ADF QPlay:2 image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png image/jpeg 48 48 24 /upnp/grender-48x48.jpg image/jpeg 120 120 24 /upnp/grender-120x120.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 urn:schemas-wiimu-com:service:PlayQueue:1 urn:wiimu-com:serviceId:PlayQueue /upnp/PlayQueueSCPD.xml /upnp/control/PlayQueue1 /upnp/event/PlayQueue1 urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/QPlaySCPD.xml /upnp/control/QPlay1 /upnp/event/QPlay1Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 A5_7B72 wiimu http://www.wiimu.com/ WiiMu LinkPlayer WiiMu LinkPlayer http://www.muzohifi.com/ uuid:FF31f0A7-7DFF-F91C-C213-1ADFFF31f0A7 V01-Mar 5 2021 00001 A5_7B72 FF31f0A77DFFF91CC2131ADF QPlay:2 image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png image/jpeg 48 48 24 /upnp/grender-48x48.jpg image/jpeg 120 120 24 /upnp/grender-120x120.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 urn:schemas-wiimu-com:service:PlayQueue:1 urn:wiimu-com:serviceId:PlayQueue /upnp/PlayQueueSCPD.xml /upnp/control/PlayQueue1 /upnp/event/PlayQueue1 urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/QPlaySCPD.xml /upnp/control/QPlay1 /upnp/event/QPlay1UPnP devices found : 1
Device #0: ID 0x0 : A5_7B72
Manufacturer: wiimu
Model name: A5
Max. memory for audio buffers: 12458MB
Local Audio Engine: CoreAudio
Local devices found : 3
Device #0: ID 0x56 EV2785
Manufacturer: ENC
Model UID: 15C31129-0000-0000-2C20-0104A53C2278
Model name: ENC EV2785
Device #1: ID 0x4f Externe koptelefoon
Model UID: Codec Output
UID: BuiltInHeadphoneOutputDevice
Model name: Apple Inc. Externe koptelefoon
Device #2: ID 0x49 Mac mini luidsprekers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Mac mini luidsprekers
