Since I updated to MAC OS 11.6, I can no longer connect airplay from Audirvana 3.5.50 to my network player. There was no problem before that. The output to the internal speaker and USBDAC is possible. Can anyone tell me how to deal with this?
Hello @Sanki,
Can you do the following procedure?
Option/alt click on the loudspeaker icon on the menu bar
Select AirPlay in the selection menu that appears
You can then select AirPlay in Audirvana Audio Device Settings.
If the loudspeaker icon is not displayed on the menu bar, you can show it by going to System Preferences, Sounds page, and set the “Show loudness in menu bar” option.
In addition, be sure iTunes is not set to use the Airplay device.
Thank you for your prompt suggestion.
I can select my network player on AirPlay from the loudspeaker icon on the menu bar, but when I select a song and click the play button, it freezes while it goes to load the file.
Can you send us a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>General>Debug Info
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content, all you have to do is paste it in response to this email
I’ve put up debug information. Is this OK?
macOS 11.6.0 with 16384MB RAM
Sync list: 2 folders
AUTO: /Volumes/HDW-PDU3/music/Berliner Philharmoniker Beethoven Symphonies1-9
AUTO: /Volumes/HDW-PDU3/music/HiRez
iTunes/Music library synchronization: last synchronized on Tue Oct 26
14:59:16 2021
Library database path: /Users/miyoshi_tetsuji/Library/Application
Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: LS50 Wireless II-tm3 Model UID:KEF LS50 Wireless
II-tm3 UID:uuid:ed6bb56a-baa2-4416-b325-fdf818d85ff2
UPnP device at http://192.168.10.105:43985/ed6bb56a-baa2-4416-b325-fdf818d85ff2.xml
ID 0x0 LS50 Wireless II-tm3 Manufacturer:KEF
Model UID:KEF LS50 Wireless II-tm3 UID:uuid:ed6bb56a-baa2-4416-b325-fdf818d85ff2
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-wav:
http-get::audio/x-flac:
http-get::audio/x-m4a:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/ogg:
http-get::audio/mpeg:
http-get::text/xml:
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/vorbis:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/wave:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/wave:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
1
0
qq:X_QPlay_SoftwareCapabilityQPlay:2.1</qq:X_QPlay_SoftwareCapability>
KEF
http://www.kef.com/
LS50 Wireless II
LS50 Wireless II
SP4025
http://www.kef.com/
78f33ecb-6bd1-4b21-b38c-ae3cf616979f
image/png
120
120
24
/LibRygelRenderer-120x120x24.png
image/png
48
48
24
/LibRygelRenderer-48x48x24.png
image/jpeg
120
120
24
/LibRygelRenderer-120x120x24.jpg
image/jpeg
48
48
24
/LibRygelRenderer-48x48x24.jpg
/xml/ConnectionManager.xml
/Control/LibRygelRenderer/RygelSinkConnectionManager
/Event/LibRygelRenderer/RygelSinkConnectionManager
/xml/AVTransport2.xml
/Control/LibRygelRenderer/RygelAVTransport
/Event/LibRygelRenderer/RygelAVTransport
/xml/RenderingControl2.xml
/Control/LibRygelRenderer/RygelRenderingControl
/Event/LibRygelRenderer/RygelRenderingControl
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/xml/QPlayDescription.xml
/Control/LibRygelRenderer/QPlay
/Event/LibRygelRenderer/QPlay
http://192.168.10.105:80/
dlna:X_DLNADOCDMR-1.51</dlna:X_DLNADOC>
UPnP devices found : 1
Device #0: ID 0x0 LS50 Wireless II-tm3 UID:
uuid:ed6bb56a-baa2-4416-b325-fdf818d85ff2 Location:
Device #0: ID 0x32 内蔵出力 Manufacturer: Apple Inc. Model UID:
AppleHDA:54 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
You are using UPnP, not Airplay. Do you see your Airpaly device in the sound preferences settings of your Mac?
Yes, if you select it, do you see it in Audirvana?
You need to select AirPlay, not the device by name in the network section below. The way you selected it now, it will use UPnP.
If you can use UPnP it’s even better than AirPlay. You just need to get it to work. Have you tried to change the “use RAW PCM” in the settings?
Also reduce the pre-load cache to 4000MB. You have reserved too much memory for Audirvana caching. Not much left for the operating system to work with.
He is using the 3.5 version of Audirvana
Ahh sorry, I overlooked that.
@Sanki it would make sense for you to try the new Audirvana Studio. It should work well with your KEFs over UPnP and you can expect sound quality improvement over AirPlay.
Thank you very much for the long correspondence.
I was able to play it by selecting Airplay.
However, when using Airplay, high-resolution audio files such as flac are downsampled, aren’t they?
What should I do to play high-resolution sound sources?
Do you recommend changing to audirvāna studio?
You can’t use AirPlay to play high resolution files. You need to use UPnP. It would make sense for you to try Audirvana Studio and test UPnP functionality with your speakers.
I have a Mac and this helped me discover “The Secret” to AirPlay and Audirvana, as well as the UPnP secret: power-cycle the app!
When Audirvana launches, it reads the available streaming routes from at least the Sound Preferences pane and any devices transmitting UPnP/DLNA over the network (Wi-Fi or wired or blended like mine). So, it needs to “see” AirPlay on launch. Otherwise, you have to quit, select by clicking on the AirPlay device in your Sound Preference pane’s output tab, and then relaunching Audirvana.
Not exactly user-friendly, but being an audiophile generally isn’t, is it? ha ha ha ;^)
Anyway, thank you Bitracer and Sanki.
Normally you shouldn’t have to restart Audirvāna Studio to see the Airplay device. When you select it in the sound panel, you should see it in Audirvāna Studio as available.
