Hi,
When connecting my AirPods to my Mac (OS Catalina) and playing Audirvana, they sound too low on max settings. When playing iTunes or TIDAL-app sound is OK.
Does anyone know how to make them sound louder ?
Have you tried the volume control on your Mac?
Volume MacOS is disabled when using Audirvana. Audirvana volume is at max.
Found the solution. Turning Exclusive Access off gives Access to Mac volume-slider in menu. Turned this to max, then put EA back on again. Now volume can be put much louder. Thank !
