hello,
album rating does to work properly, it is a simple function that should work like in audirvana 3,5
there is no correlation between the tag and the audirvana stars, if i put 3 stars in tag, audirvana displays 5 stars
if i rate the album 3 stars in audirvana, the albumrating tag is erased
also most important is, an album rated 3 stars is displayed in a playlist with albums rated 2 stars
how can I fix this mess?
