Any quick fix?
Same problem here. Many CD’s have the same cover in the database. But if you play that cd it gives the right cover.
Im using musicbee now.
Works perfectly.
Wasapi and bit perfect.
Album shows correctly
musicbee is a windows program and i have an IMac.
Hello @Steinarvk, does the albums with the same album covers have a cover in their metadata or in the folder that contains the track of the albums?
