I have several albums with the same title say
Schumann: Piano Works
But by different artists, AS seems to merge these together
How do I separate these without adding the Artist Name to the album name ?
I have the exact same problem happening with ‘Music of the Spheres’ where 3 completely different artists get lumped together in one entry showing as 3 discs in there which makes it hard to find.
Mike Oldfield - Music of the Spheres
Coldplay - Music of the Spheres
Mannheim Steamroller - Music of the Spheres
Would be better if albums with the same name but different artists get separated into their own entries instead of lumped together.
Cheers, Hans.
Honouring a [version] tag may help,where you split off say DSD, Deluxe, etc as separate albums . In big libraries it’s not uncommon to have multiple versions of Albums
A select of Artist, Album would be a start rather than just Album as it appears to be @Antoine
Hi @Antoine sorry I was completely occupied with the SWAF24 and Axpona 24 audio shows so I will dive into this now again as it is still a small issue.
Cheers, Hans.
