This seems to affect all the songs that I have tried to play using the software. The correct song title appears in the lower left hand corner next to album artwork, however every song so far has the word ‘America’ in front of it.
Something must have changed the metadata in bulk.
Will I have to go into the original file location to change it back or can I change the metadata using Audirvana?
Try to figure out what changed the metadata in the first place. Maybe you can bulk change it back to normal.
Hello @AmarulaGold, you can change the metada in Audirvana. The “America” is displayed only when you starting the playback?
