Bonjour Damien,
Merci de ce retour, voici donc les infos.
Et félicitations en direct pour cet excellent logiciel !
Licence enregistrée pour Laurent
No plugin active
Bandwidth at 0dB = 87.5459
Filter max length = 15184
Anti-aliasing = 92.9279
Phase = 53
Replay Gain: by track
Sync list: 2 folders
AUTO: /Volumes/Musique D-Z/
AUTO: /Users/laurent/Desktop/Musique A-D
Library database path: /Users/laurenttarrade/Documents/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Max. memory for audio buffers: 7638MB
McIntosh-HD HS USB Audio
Model UID:McIntosh-HD HS USB Audio:2AFD:0002
UID:AppleUSBAudioEngine:McIntosh:D150:14100000:2
ID 0x33 Sortie intégrée Manufacturer:Apple Inc.
Model UID:AppleHDA:88 UID:AppleHDAEngineOutput:1B,0,1,2:0
Stream ID 0x34 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x33 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
